Break fluid leak - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 2nd, 06, 08:43 AM Thread Starter
Kurt
Break fluid leak
I still haven't been able to get any fluid to the rear brake cylinders yet, but now I have another problem. I have a leak where the front rubber brake hose connects to the disk brake caliper. It looks like it is leaking on the caliper side of the brake hose fitting. The bolt is tight, but I may have screwed up with the brass washers. Can someone tell me how it goes. I have it as follows: The caliper-brass washer-hose end brass washer-bolt.. It been a while since I put it back together but I remember haveing some of the washers left over.
KURT is offline
post #2 of 4 (permalink) Old Jul 2nd, 06, 09:23 AM
Re: Break fluid leak
Are you sure that the washers are brass? They should be copper, and should be replaced with new when removing the hose. Also, insure that you have the correct I.D. washers. Your installation order sounds right with a washer on either side of the hose fitting......Jb
Beat it to Fit, Paint it to Match!
Johnny B is offline
post #3 of 4 (permalink) Old Jul 2nd, 06, 09:23 AM
as long as you have a brass washer on each side of the banjo) like you have it), it's expected to seal
post #4 of 4 (permalink) Old Jul 2nd, 06, 02:50 PM
elonblock
A couple of things you may want to consider...
Have you checked the fittings to make sure there
is no dirt on the seat and it is seated properly?
Also check the washers to makes sure there are NO
burrs on them which would prevent a proper seal.
Are you sure the material of the washers is brass?
As someone mentioned earlier, it should be copper,
because it is soft and will form an airtright seal.
It sounds like you are getting pressure from the
master cylinder. Progress is good!
What did you find?
Elon
elonblock is offline
Trans Fluid leak stain on driveway thedugan Bench Racing 10 Jun 2nd, 06 04:45 AM
Power steering fluid leak - 69 RS chriss69 Brakes, Suspension & Steering 0 Dec 22nd, 05 12:03 PM
Brake Bleeding the right way WillS Brakes, Suspension & Steering 0 Feb 14th, 05 03:45 PM
Trans fluid leak at yoke? pa69camaross Transmission & Driveline 3 Oct 4th, 04 01:04 AM
Trans Fluid Leak at Speedo Cable Trans Fitting Desert 68 Transmission & Driveline 2 Jun 26th, 04 03:07 PM
