Bolt on SFCs - Team Camaro Tech
post #1 of 23 (permalink) Old Jul 2nd, 06, 07:51 PM Thread Starter
MaryBeth
Bolt on SFCs
Okay...I've been searching and reading but can't seem to find the answer I'm looking for.
We installed one of the bolt in sfcs I have and found a minor problem with bolting to the front subframe. It seems that the bushing slips thru the fork opening on the sfc. I am thinking to fabricate a steel plate, maybe 1/8" thick to put between the bushing and sfc with a hole big enough fo only the bolt to fit thru.
The connectors I have are similar to the bolt ons that are sometimes on ebay...don't know if they are the same but could be. I didn't buy them. They were in a box of parts that were with the car...
Any additional suggestions? I don't know if I explained this right. If not, let me know and I'll try again...
MaryBeth's 67 moneypit
mbmmca is offline
post #2 of 23 (permalink) Old Jul 3rd, 06, 04:21 AM
Banned
Smile Re: Bolt on SFCs
It has to slot around the bushing back there.
And the bushing halve's fit through the S/F mount and center such that the bolt can locate a tad off if needed.
You can do it but then you effectively do away with any self centering/ bushing interlocking IF I recall right??
pdq67
post #3 of 23 (permalink) Old Jul 5th, 06, 04:09 PM Thread Starter
MaryBeth
Re: Bolt on SFCs
After some serious messing around, we got the back bolted up. Unfortunately we are still running into problems with the front. The bushing that would normally be on the bolt and meet with the sleeve squishes through the sfc. Seems that the sfc is too big for the bushing....I'm so confused, and hubby's interest in either car is wanning, so it looks as though I fix this one myself... but I have no idea how. Engineer I am not!
mbmmca is offline
post #4 of 23 (permalink) Old Jul 5th, 06, 05:11 PM
67LSRS
Re: Bolt on SFCs
Are you using stock rubber body bushings? If so are they new? If they are old ones this could be the problem, most SFC's MFG's recommend using solid bushings (Aluminum) with sfc. If they are old origionals they may be to sloppy to maintian there shape when tightening them and thus pull through the connector. New rubber bushings should do the trick many use them with sfc's but I would recommend going to solids for more frame stiffness. I had the bolt ons on mine they were Competition Engineering and they worked fine they fit the bushing fine but they were solid bushings.
_____________________________________________
My 67 RS Project:
LS1, FAST XFI 2.0, Turbo 350, 12 Bolt 3.73's.
67LSRS is offline
post #5 of 23 (permalink) Old Jul 5th, 06, 08:08 PM Thread Starter
MaryBeth
Re: Bolt on SFCs
New rubber bushings. They don't seem to fit. Enlighten me on solid bushings....never heard of 'em (yep that's the girl in me...) So fill me in, including where to get them please....
mbmmca is offline
post #6 of 23 (permalink) Old Jul 5th, 06, 08:17 PM
67LSRS
Re: Bolt on SFCs
Most of the high performance suspension mfg's have them Competition Engineering, Detroit Speed etc... Try Summit Racing, Jeggs And DSE.
Heres Summit (A Link to there CE's) http://store.summitracing.com/partde...5&autoview=sku
Tomorrow night I will measure the opening on my bolt ins, for you.
My 67 RS Project:
67LSRS is offline
post #7 of 23 (permalink) Old Jul 6th, 06, 03:24 AM Thread Starter
MaryBeth
Re: Bolt on SFCs
Thanks. The SFCs I have could be the ones pictured in the Summit and Jegs catalogs....These solid bushings will do the trick huh? Cool. Ordering today. I am assuming installation is pretty self explanitory?
mbmmca is offline
post #8 of 23 (permalink) Old Jul 6th, 06, 05:41 AM
Re: Bolt on SFCs
Solid bushings will transmit a lot of vibration and noise so, be warned!
The subframe connectors are a sloppy fit where they meet the subframe. This in normal for these out-of-the-box connectors.
They must slip into the subframe and become sandwiched between the two-part bushings.
Unfortunately, the bushings will not sit well with the open connctor's hole and also the bushing are not designed to reach through 3/8" of steel. They where only design for 1/4".
I don't have any real advise except try and use the rubber bushings for ride comfort. Alternatively, you can do what I did and make your own connectors that fit YOUR car exactly and don't have an open hole where the bushings & bolts pass through.
The plates on the side are my traction bar lift points.. You don't need those!
BlackoutSteve is offline
post #9 of 23 (permalink) Old Jul 6th, 06, 09:19 AM Thread Starter
MaryBeth
Re: Bolt on SFCs
Interesting thought, however, fabrication is not my stong suit. If I close in the opening to just big enough for the bolt, will that work? I will still try the bushings first, since I can get them locally...but if they are that bad.....
mbmmca is offline
post #10 of 23 (permalink) Old Jul 6th, 06, 12:31 PM
Re: Bolt on SFCs
Use poly-mounts, the best of both worlds.
TJS69 is offline
post #11 of 23 (permalink) Old Jul 6th, 06, 12:42 PM Thread Starter
MaryBeth
Re: Bolt on SFCs
???????????? Enlighten please...
mbmmca is offline
post #12 of 23 (permalink) Old Jul 6th, 06, 02:50 PM
Banned
Re: Bolt on SFCs
I had to use a hacksaw to notch my black, hard as frozen hockey pucks Poly S/F bushings and my Jegs bolt-on S/F/C's went right on!
I did however use Cornholio's suggestion to use onna my small floorjacks as a third hand to push them up next to the floorpans and it worked GREAT!!
pdq67
post #13 of 23 (permalink) Old Jul 6th, 06, 05:51 PM
67LSRS
Re: Bolt on SFCs
Ok, heres a link to some pictures, you can see where the bushing sat in the connector as it didnt get hit with paint, from the side you can get an estimate on how far it sat in the frame. The actual hole/slot for the bushing end measures 1 1/4" in width and 2 1/4" deep the actual arc starts at 1 1/2" from the frame end of the connector. These were on the car when I purchased it and it was a drag car PDQ and others are right you will get more vibration and noise with solids. I have purchased the DSE connectors that weld in and I plan to use the solids with these and from what others have said the extra vibration and noise is not that bad. I will let you know when I get it on the road, but it will be awhile LOL.
Link to Bushing End: http://community.webshots.com/photo/...77826120gJdKpd
Link to Side Http://community.webshots.com/photo/443555202/2606291670077826120BKbdmL
My 67 RS Project:
67LSRS is offline
post #14 of 23 (permalink) Old Jul 6th, 06, 06:44 PM Thread Starter
MaryBeth
Re: Bolt on SFCs
One of the machine guys I work with said he can cut a 1/8" plate to fit inside the connector with a hole only big enough for the bolt to go thru. Will this work?
Sitting here looking thru Classic Ind. catalog, on page 429, there are two kits shown. One has steel sleeves, the other does not. I am not entirely blonde, but aren't the sleeves important???
mbmmca is offline
post #15 of 23 (permalink) Old Jul 6th, 06, 07:50 PM
Re: Bolt on SFCs
Yes the sleeves in the bushings are extremely important. Otherwise, your subframe will move considerably in the event on an accident and would most likely act as a guillotine and shear those bolts in half leaving your Camaro (and maybe you) in 2 pieces!!
Any 1/8" plate you have made MUST have a hole in it to accomodate the bushing's sleeves.
12 bolt swap in 1967 Camaro jrt67ss350 Brakes, Suspension & Steering 5 May 3rd, 07 07:38 PM
Door adjustment jsouthco68camaro Body Shop 9 Mar 7th, 05 05:46 AM
1968 door alignment Steve W Body Shop 5 Sep 9th, 03 04:15 PM
12 bolt swap......wrong rear end Damon Colson Brakes, Suspension & Steering 14 Mar 19th, 02 12:22 AM
Hanging Doors ? wesley58_do Body Shop 6 Jan 30th, 02 11:23 AM
