What part is adjusted to set caster? - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 4th, 06, 06:21 AM Thread Starter
Hi all
i have a previous post on asking what specs to set for the front end alignment. Just so i know what the shop will be doing, I know the camber is set with shims in the Upper Control Arms and the toe in is set with the threaded rod on the Inner/outer Tie rod ends. What is the part that is adjusted to set the caster, I cannot find any info on what they change to make this setting? I just like to know what they will be doing to the car.
Ray
ray moore is offline
post #2 of 3 (permalink) Old Jul 4th, 06, 06:53 AM
Re: What part is adjusted to set caster?
Same shims that are used for camber. The shop will just use a little more shims under the front or rear stud. More shims under the front stud adds positive caster, more under the rear adds negative caster.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #3 of 3 (permalink) Old Jul 4th, 06, 04:47 PM Thread Starter
Hi Mark C
Thanks for explaining that, it make sense once pointed out. I kept thinking what the heck do they adjust, their's nothing else adjusable. A big DUH! on my part.
Ray
"Basics of Basics" Making Templates for cutting and drilling accuracy. MARTINSR Body Shop 3 May 13th, 10 06:06 PM
New Stroker Engine...But...A Problem (Long) bigdawginva Performance 57 Mar 11th, 05 02:33 PM
Part #'s needed for the front & rear windshield chrome trim johnnyr Body Shop 1 Dec 21st, 04 05:39 AM
69 Z28 Starter Solenoid Part Number rszmjt Tag Team 2 Mar 8th, 04 12:02 AM
GM Part # to a ? 67w522 Body Shop 0 Mar 5th, 03 03:14 AM
