Tie Rod coupler-sleeve - Team Camaro Tech
post #1 of 2 (permalink) Old Jul 5th, 06, 03:48 AM Thread Starter
Hi,
Does anyone know how tight the two bolts should be on the sleeve for the tie rods?
Not looking for actual torque numbers, just an idea of tightness, real tight, tight, snug? Mine were not really even tightbasically just snug, normal?
thanks
Joe
faninc is offline
post #2 of 2 (permalink) Old Jul 6th, 06, 12:17 AM
Re: Tie Rod coupler-sleeve
Get yourself an Assembly Instruction Manual (a bible) for your Camaro. All the info is there..
108-156 in/lbs (9-13 ft/lbs) is the spec. (UPC-9)
The AIM also shows how the clamps should be positioned in relation the sleeve slot, and the tie rods themselves. The books are worth their weight in gold.. Get one!
BlackoutSteve is offline
Solid vs Stock Tie Rod Sleeves thedong Brakes, Suspension & Steering 5 Jun 6th, 06 11:50 AM
New Tie Rod Clamps VS Originals ????? CamarosRus Brakes, Suspension & Steering 5 Dec 27th, 05 08:45 PM
Tie rod ends.. wizard67 Brakes, Suspension & Steering 13 May 29th, 05 04:13 PM
Tie rod length rcatalano Brakes, Suspension & Steering 8 May 19th, 05 06:17 PM
