front wheels centered steering wheel is not - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 6th, 06, 11:28 AM Thread Starter
Harry
dawg's Avatar
ok i got manual steering box and after changing the steering wheel and turn signal cam the steering wheel is off center to the left a bit
while driving down the road.
turn signals work fine and steering lock works and locks in the correct position.
im assuming i gotta either reposition the rag joint coupling or reposition the steering shaft intoo the steering box.
the steering wheel only had 1/2 inch to 3/4 inch play at the steering wheel so the box is adjusted correctly in accordance to the manual.
434 stroker
US Navy retired
dawg is offline
post #2 of 6 (permalink) Old Jul 6th, 06, 11:31 AM
Re: front wheels centered steering wheel is not
Can you remove the steering wheel and index it over on the splines?
onovakind67 is offline
post #3 of 6 (permalink) Old Jul 6th, 06, 11:51 AM
Farm Boy's Avatar
A front end alignment will fix it. The mechanic will center the wheel before he adjusts the tie rod sleeves to set the toe-in.
Farm Boy is offline
post #4 of 6 (permalink) Old Jul 6th, 06, 02:51 PM Thread Starter
Harry
dawg's Avatar
steering wheel spline is keyed so you cant do that.
yes i think a front end alignment might fix this for sure.
434 stroker
US Navy retired
dawg is offline
post #5 of 6 (permalink) Old Jul 6th, 06, 06:07 PM
This paper describes all the connections in the steering system and provides tips on steering wheel centering for First Gen Camaros.
http://jimshea.corvettefaq.com/wp-co...Rev18MY062.doc
JIML82
JIML82 is offline
post #6 of 6 (permalink) Old Jul 7th, 06, 11:58 AM Thread Starter
Harry
dawg's Avatar
nice thks for the info JIML82
434 stroker
US Navy retired
dawg is offline
Steering Column reassembly Steptoe Camaro Tech 17 Jan 23rd, 07 08:48 PM
Safety of reproduction steering wheel 68 VT Interiors 16 Mar 16th, 06 02:17 PM
Steering Box help-Want to lose the loose wheel Steering faninc Brakes, Suspension & Steering 13 Jul 30th, 05 09:55 PM
Power steering problem after front end rebuild BC Brakes, Suspension & Steering 4 Jul 7th, 05 09:15 PM
Is this a 68 Steering Wheel? ohayden Interiors 13 May 3rd, 01 09:24 AM
