Where can I get moog coil springs - Team Camaro Tech
post #1 of 17 (permalink) Old Jul 10th, 06, 02:41 PM Thread Starter
Dan
I have went to several parts stores,here in detroit subburbs.
and noboby carrys the moog 6308 coil springs.I would like to try them because everybody has good reviews on this coil spring(looking for the right ride height for my 69 coupe)
does anyone have a parts guy that I can get a hold of or know a place I can order them.
thanks.
________________
Dan
pappy's69 is offline
post #2 of 17 (permalink) Old Jul 10th, 06, 03:35 PM
Farm Boy's Avatar
Re: Where can I get moog coil springs
I got my front springs from a small Car Quest auto parts store near my house. I gave them the Moog part number. They were not in stock and had to be ordered. I had them in two days.
Farm Boy is offline
post #3 of 17 (permalink) Old Jul 10th, 06, 03:43 PM
Chris
Moog has a warehouse (in Louisville) for parts distributors located here in central Ky.
if you don't have any luck in your area, I'd be glad to get a phone # for you;
you can order the parts from them and I'll deliver 'em to you August 18th when we come to the Woodward Cruise
'69 SS X66 Camaro
454, TH400 & GearVendor, 12 bolt
'82 Corvette.
stock
'81 Camaro Pro Bracket car.
406, TH350, 10 bolt, NHRA #3148
82Vettrin is offline
post #4 of 17 (permalink) Old Jul 10th, 06, 05:21 PM
Brent
Brentmc's Avatar
They are sold under the TRW name too--I got them at Advance Auto as
TRW CS6308. Ask for front coil springs for a 1969 camaro 6 cyl w/AC.
You can also buy them from Rock Auto.com
I have these springs--here's a pic with them in:
1968 RS/SS Lemans Blue
Brentmc is offline
post #5 of 17 (permalink) Old Jul 10th, 06, 07:54 PM
Brent
Brentmc's Avatar
The fronts are 235/60/15 and the rear 255/60/15 with KYB Gas Adjust shocks
Brentmc is offline
post #6 of 17 (permalink) Old Jul 10th, 06, 08:17 PM
"Tri-Tip"
Gary L's Avatar
Summit sells Moog also.
Gary L is offline
post #7 of 17 (permalink) Old Jul 10th, 06, 10:45 PM
Call me Funk
Send a message via AIM to CFunK
Brent's car is a PRIME example of how YMMV with regard to springs, suspension, tire size and ride height. His front sits about an inch lower than my '67 with the same tires and springs.
Brent, what springs are you running in the rear?
Nice ride and love the vinyl top.
-Funk
CFunK is offline
post #8 of 17 (permalink) Old Jul 11th, 06, 04:10 AM
Brent
Brentmc's Avatar
I followed CFunk's lead entirely in rebuilding my front suspension and copied what he did--his ride height is perfect and the car is beautiful. I think I know his car's ride height specs better than mine thanks to his website. Thanks Chris!
The rear springs were installed in the mid-1990's and are from Napa (part number 21-245R)--I'm not sure what that breaks out to, but I'm satisfied with the height.
The current set-up does rub on the driver's side front at about the 11 o'clock position if I hit a dip in the road. I'm planning to have it aligned and hope that it toes in enough at the top to eliminate this problem.
Dan--did you decide where to get your springs?
Brent
Brentmc is offline
post #9 of 17 (permalink) Old Jul 11th, 06, 08:20 AM
Farm Boy's Avatar
You could also use Moog 6320 springs. They have the same rate as the 6308’s but will ride 3/8 to 1/2 inch higher. This should help keep the tire off the fender when you hit a dip in the road.
Also when you have it aligned have them set the camber at 0˚ to -1/2˚ negative (the factory specs call for 1˚ positive). This will bring the top of the tire in and will hopefully cure the rubbing issue plus it will handle better.
I believe CFunk’s front end rides a bit higher than other cars with the 6308 springs. The front end height of Brentmc’s 68 is what you can expect with the 6308’s.
Farm Boy is offline
post #10 of 17 (permalink) Old Jul 11th, 06, 02:48 PM Thread Starter
Dan
Thanks everybody!!
Today I got cold feet on the 6308 springs and I ordered some 6320 from Summit Racing,(they will drop ship them and I will have them in two days)
I notice that with the 6308 springs that the 67/68 cars, would have a rub with 235/60-15 tires.The 67/68 have thoes nice radious wheel wells and my 69 are not as radious.So I ordered the 6320 spring.I have 15x7 with 4.5 b.s.rallyes.Tires are 235/60-15 front 275/60-15 rears.Next I will adjust the rear end height NEXT.
82 vettrin----Sorry, Maybe we can meet at the cruise anyways!!!
Is there a camaro meeting at the woodward cruise?
___________________________________________
Dan
post #11 of 17 (permalink) Old Jul 11th, 06, 03:06 PM
Brent
Brentmc's Avatar
Dan,
If you don't mind, post back with your front end height once you change out the springs. I'm interested to know the installed difference between the two springs.
Brent
Brentmc is offline
post #12 of 17 (permalink) Old Jul 12th, 06, 09:20 AM
Call me Funk
I agree with Steve's statement about my front end being a little higher than most with the 6308's. I might go the Hotchkiss route in the front to get another .5" - 1" drop and going with a 225/60/15 tire up front.
-Funk
CFunK is offline
post #13 of 17 (permalink) Old Jul 16th, 06, 06:27 PM Thread Starter
Dan
Talking Re: Where can I get moog coil springs
well---Here Is a update!!!
I just installed my new moog 6320 springs(wow!!! was it hot today) And the ride height is now 25 7/8 from the ground to the bottom of the fender.Now remember I have a 69 and they don't have the same wheel well openings as a 67/68.The front tires are 235/60-15 and the rallyes are 15-7 with 4.5 b.s.They fit great with only one exception,On a full lock turn they rub very-very little on the inside frame (only cleans the dirt off the inside frame) This is exceptible to me.In the future I may install a steering stop. Maybe
When I convert to the disc brakes everything will be OK.
Thanks EVERYBODY for you Help.
Dan
post #14 of 17 (permalink) Old Jul 16th, 06, 06:59 PM
Brent
Brentmc's Avatar
Great--I'm glad it came out the way you wanted. Any pics?
Brentmc is offline
post #15 of 17 (permalink) Old Jul 16th, 06, 07:19 PM
Banned
I think '69 cast one piece rotor/hubs will move each wheel out like 7/16" or so vs drum hubs!
There is a difference in "height" or "J" (if you will) between the two where the wheel centers mount..
At least on '67 cars like mine.
I think David Pozzi has a pic of this on his great site if you want to look into it more..
pdq67
Moog 6308 Coil Springs on V8 RS...too small? Brentmc Brakes, Suspension & Steering 6 Dec 17th, 05 10:59 PM
front coil spring's 19694speed Brakes, Suspension & Steering 4 Nov 23rd, 05 07:45 PM
6308 moog coil springs Chef Ron Brakes, Suspension & Steering 3 Aug 12th, 04 09:10 AM
Moog Coil Springs 6308 where to get??? Erik Beckett Brakes, Suspension & Steering 5 Jun 13th, 03 04:44 PM
