'69 Z/28 Steering Box Lube Check - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 11th, 06, 09:12 AM Thread Starter
Question '69 Z/28 Steering Box Lube Check
All,
Can someone tell me how to check the lube in a í69 Z/28 manual steering box? I donít see any kind of check plug or anything. I did a search on this website and didnít find anything, but I may not have been using the right search words. Thanks.
Doug
dh302 is offline
post #2 of 5 (permalink) Old Jul 11th, 06, 03:10 PM
parkbrau's Avatar
Re: '69 Z/28 Steering Box Lube Check
Doug, my memory is foggy on manual boxes. But isnt there a side cover? I think thats where you would pack the grease/lube in it. You would also have to replace that seal. I remember it has to be 3/4 full to allow for air gap or something like that. Again, this is from memory. Checki it out and see if that makes sense.
I will look in the chasis service manual and see what I can find tonite.
I hate to repeat this, but the chasis service manual and the assembly manuals are priceless additions to your garage's book shelf. That is if you dont already have them.
parkbrau is offline
post #3 of 5 (permalink) Old Jul 11th, 06, 05:06 PM
JohnZ's Avatar
There are three bolts attaching the top cover - you fill it through the front hole, and check it through the middle hole.
JohnZ
CRG
JohnZ is offline
post #4 of 5 (permalink) Old Jul 12th, 06, 08:12 AM Thread Starter
Smile Re: '69 Z/28 Steering Box Lube Check
All,
OK, thanks. I'll try that tonight. When you say fill it through the front hole I assume you are referring to the bolt that is towards the front of the car. I would have thought this bolt hole would be at a lower elevation than the middle bolt hole making it hard to get the oil level to the. Iíll look at it tonight and maybe it will make sense to me. If Iím thinking right this cover has the stud and locknut in the middle of it that adjusts the gear lash which I assume I wouldnít want to be turning it any. Does it take 80/90 gear lube?
Thanks.
Doug
P.S. I have the Fisher body manual, but Iím going to check into getting the chassis service manual and assembly manual.
dh302 is offline
post #5 of 5 (permalink) Old Jul 12th, 06, 10:52 AM
Use a good grade lithium based chassis (ball joint) grease. Just don't overfill the gear. You want some air space inside the gear to allow for expansion of the grease with underhood temperatures. You do NOT want to mess with the slotted screw and lock nut in the center of the cover.
JIML82
JIML82 is offline
Replacement Part Numbers for Steering/Suspension - LONG HwyStarJoe Brakes, Suspension & Steering 14 Sep 16th, 12 10:50 AM
Ripped off on a steering box? Joes_68 Brakes, Suspension & Steering 6 Dec 18th, 05 07:47 PM
AGR or Cardone steering gear box? ENP Brakes, Suspension & Steering 6 Nov 16th, 05 08:21 PM
steering column binding Seakane Brakes, Suspension & Steering 16 Jun 6th, 04 03:06 PM
Suspension Parts List davidpozzi Brakes, Suspension & Steering 3 Feb 23rd, 04 01:54 AM
