boosters - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 11th, 06, 02:14 PM Thread Starter
boosters
I'm running a BBC with (I think) a 11" booster. I measured the entire over all diameter.
My master cylinder is leaking and I want to change it. I know NOTHING about how to do that so I'm hiring it done.
Due to not having much room in the engine compartment, I thought maybe I'd run a smaller booster.
I have a very radical cam so with this 11", I run a vacume canister to 'accumulate' vacume.
Can I get away with a 9" booster?
7"?
Not interested in running a vacume pump.
Seeking advice.
mkpatrick is offline
post #2 of 5 (permalink) Old Jul 12th, 06, 12:12 AM
Re: boosters
you could use a dual diaphragm 9" and it would give about the same amount of assist as the 11" (maybe even a little more?)
i read that an 8" dual diaphragm has about the same surface area as a single 11"
400bird is offline
post #3 of 5 (permalink) Old Jul 12th, 06, 01:20 PM Thread Starter
Re: boosters
Thank you sir....
tiz the way I will go...
post #4 of 5 (permalink) Old Jul 13th, 06, 12:44 AM
Re: boosters
yup sure thing
i got a 8" dual for my car, it only had about 7" of vacuum in gear at idle
and with the new booster it works great
i searched here and asked and could not get an answer so i just tried it and have been very pleased
here is where i ordered it
http://www.hotrodsusa.com/
here is the booster i got
http://www.hotrodsusa.com/store/product328.html
and you will need the brackets near the bottom of the page
67-72 CHEV POWER BRAKE BRACKET:
http://www.hotrodsusa.com/store/boosterchev.html
400bird is offline
post #5 of 5 (permalink) Old Jul 13th, 06, 08:40 AM Thread Starter
Re: boosters
This is highly encouraging. It will give me more room my current 11" booster is about an inch from the valve cover.
Downleg vs. Annular Boosters rockertype Engine 1 Jan 9th, 06 05:50 PM
Cell phone antenna boosters? camaro man Bench Racing 4 Jul 24th, 05 03:55 PM
Theory On Brake Boosters & Needed Vacuum.. Go69 Brakes, Suspension & Steering 8 May 24th, 04 07:53 AM
Annular boosters vs. ? travis Performance 4 Sep 11th, 02 07:34 AM
