Air Noise Problem From Brake Application - Team Camaro Tech
post #1 of 2 (permalink) Old Jul 11th, 06, 03:42 PM Thread Starter
Red face Air Noise Problem From Brake Application
I installed a new power brake unit, disc calipers, ball joints, tie rods, coil springs, a whole new suspension on my '69. But when I apply the brakes, they grab just fine but I'm hearing a "whoosh" sound. I think its a vacuum sound. Another amateur garage mechanic thinks the new brake booster is defective; I don't think so because the brakes are working fine. Any ideas, gentlemen?
Salerno is offline
post #2 of 2 (permalink) Old Jul 11th, 06, 05:02 PM
JohnZ's Avatar
Re: Air Noise Problem From Brake Application
The "whoosh" sound is normal - that's air being drawn into the back of the booster; that said, there's supposed to be a foam seal where the pedal pushrod goes into the back of the booster that acts as a muffler where that air enters. If the seal is missing, you'll hear the air - if it's in place, you won't hear it.
JohnZ
CRG
JohnZ is offline
Power brake problem foreverlookin Brakes, Suspension & Steering 2 Oct 6th, 05 01:31 AM
brake pedal problem daywin98 Troubleshooting 4 Sep 20th, 00 09:23 AM
fuel problem HELP jokerdwarf Troubleshooting 2 Dec 11th, 99 03:17 PM
fuel problem HELP jokerdwarf Tech 2000 3 Dec 7th, 99 06:41 AM
