control arm bushing? - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 11th, 06, 08:20 PM Thread Starter
I'm getting ready to have my control arms powder coated and can't really tell what pieces are meant to come out with respect to the bushings. Do I beat them in or out? I know the question sounds silly, but I've got two subframes and they arms on both are either rusted or dirty to the point I can't see any indicators.
Also in the upper conrol arm there is a rubber pad which has a nipple poking through the top. Does this thing have a name?
-Inet
inetquestion is offline
post #2 of 4 (permalink) Old Jul 12th, 06, 09:58 AM
Joe
Re: control arm bushing?
The bushings are removed from the outside of the arm. They have a lip on the outside edge. the upper arm's holes have a raised outside edge that stops the bushings from being flush against the arm, and the lower arm allows the bushing to be flush against the arm. I happened to have a hydraulic press so I could do mine myself (although it was still something of a pain.) I pushed out the old ones and pressed in the new. Beating the old bushings out with a hammer might bend up the edges and make it harder to remove. You might want to have an auto shop install the new bushings.
The rubber thing is just called a bumper, and is there I think so that the arm does not hit the frame in case it bottoms out.
67 RS with 4 barrel smallblock 350. See the USA in your Chevrolet...
Eighttrakz is offline
post #3 of 4 (permalink) Old Jul 12th, 06, 10:39 AM
Banned
Thumbs up Re: control arm bushing?
I used my cheap $10.00/$15.00 Harbor freight Tool air chisel using a cold chisel bit to knock them out! Worked fine.
Do a search under me to find out all the ends and outs of doing this correctly b/c we, (the guys and myself), have posted a lot about doing this to save us cheap-SK-8's some money!!
It's actually easy to do if you want to, imho.....................
pdq67
post #4 of 4 (permalink) Old Jul 12th, 06, 12:03 PM
Cool Re: control arm bushing?
I like the Swiss Chees method of drilling the rubber bushing so full of holes they fall out then press in the new ones after you get the outer sleves out (hack saw a slot and they fall out).
Larger Dave
Larger Dave is offline
Replacing Control arm bushings? ray moore Brakes, Suspension & Steering 15 Oct 16th, 14 05:33 AM
Issues with control arm bushings Desperado Brakes, Suspension & Steering 5 Jul 13th, 06 06:13 AM
Can't get the spindle off Lower Control Arm mine_is_blue Brakes, Suspension & Steering 15 Apr 29th, 06 07:39 PM
Upper control arm bumpers 68greg Brakes, Suspension & Steering 2 Jan 13th, 06 05:02 AM
