Caliper hitting sway bar - Team Camaro Tech
post #1 of 11 (permalink) Old Jul 14th, 06, 12:10 AM Thread Starter
mark
Exclamation Caliper hitting sway bar
Hi guys, I just installed some smokin wilwood brakes on the front of my 68 camaro and am now noticing the caliper is hitting the sway bar as I freely rotate the rotor/spindle assembly. I can't be sure if the steering would bottom out before this happens while driving but it has me concerned. Should the caliper be positioned toward the rear of the car? I currently have it positioned toward the front of the car......meaning when looking straight at the passenger wheel, the caliper is on the right hand side of the spindle - toward the front of the car.
Anyone else ever come across this?
Thanks in advance.
68camarors is offline
post #2 of 11 (permalink) Old Jul 14th, 06, 03:29 AM
Guess
HwyStarJoe's Avatar
Re: Caliper hitting sway bar
Calipers to the rear.
HwyStarJoe is offline
post #3 of 11 (permalink) Old Jul 14th, 06, 06:54 AM
yup
post #4 of 11 (permalink) Old Jul 14th, 06, 07:53 AM
DjD
DjD's Avatar
Not familiar with the Wilwood kits but here's two shots of my C5 install. Front is to the left...
...Dennis
DjD is offline
post #5 of 11 (permalink) Old Jul 14th, 06, 10:00 AM Thread Starter
mark
Unhappy Re: Caliper hitting sway bar
!!!!!!! Everything is shimmed, locktited, and torqued now too!!!! Gotta take it all apart and start over.
Ok, thanks guys for your replies. See any issues with cracking the locktite seals? Will I need new bolts and nuts? And will I need a hammer drill to get everything apart now?
post #6 of 11 (permalink) Old Jul 14th, 06, 10:06 AM
DjD
DjD's Avatar
Hardware should be re-usable... What Loctite did you use? That will decide how hard everything is to loosen. Check www.loctite.com for more on bonding and breaking the bond...
...Dennis
DjD is offline
post #7 of 11 (permalink) Old Jul 14th, 06, 03:10 PM Thread Starter
mark
Red Loctite. I just hope it will come apart. The countersink allen type bolt had better be strong.....
Thanks again, gonna be a long nite!!!!
post #8 of 11 (permalink) Old Jul 14th, 06, 06:59 PM
Guess
HwyStarJoe's Avatar
Yeah, I'd reuse the hardware too. I used the red also, but haven't had to remove anything yet.
post #9 of 11 (permalink) Old Jul 14th, 06, 07:17 PM
DjD
DjD's Avatar
If it's #271 it's removable with heat and hand tools...
http://loctiteproducts.com/repairs.a...=5&Product=154
...Dennis
DjD is offline
post #10 of 11 (permalink) Old Jul 15th, 06, 09:58 AM
Guess
HwyStarJoe's Avatar
Yeah, the red High Strength 271 is what I used.
post #11 of 11 (permalink) Old Jul 17th, 06, 10:50 PM
David Pozzi
davidpozzi's Avatar
You could just swap spindles side to side, but the steering arms have to stay on their respective sides.
davidpozzi is offline
Addco Sway Bar Questions (1-1/8") MrDanB Brakes, Suspension & Steering 19 May 10th, 06 08:09 PM
Friend gave me Addco rear sway bar, install it or not? ray moore Brakes, Suspension & Steering 12 Apr 1st, 06 05:16 AM
balancer hitting sway bar Brad74 Engine 17 Mar 25th, 06 06:33 PM
what size sway bar? garyj Brakes, Suspension & Steering 5 Jan 12th, 06 09:42 AM
Hotchkis sway bar 400bird Brakes, Suspension & Steering 3 Jul 10th, 05 01:43 AM
