Brake line clips install? - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 15th, 06, 01:21 PM Thread Starter
ENP
Here is a dumb question. I am installing new SS brake lines and new line clips. Its been about 10 months since I removed the old line. I forgot where the clips go is there a diagram floating around here on this site showing the proper location. My new clips came with two blue clips and the rest are stainless.
ENP is offline
post #2 of 5 (permalink) Old Jul 18th, 06, 08:01 PM
Call me Jim
Send a message via AIM to brightblue87iroc
Re: Brake line clips install?
A repro GM Assembly Manual shows where they all go, at least on a '68. Maybe I can make a copy. What year is yours?
brightblue87iroc is offline
post #3 of 5 (permalink) Old Jul 18th, 06, 08:08 PM
Send a message via AIM to RamAirDave
The blue clips usually go on the side of the frame rails, in the rocker area (this is from memory, but I'm pretty sure).
If its the same kit that Ive always used, there might be some that are different sizes. The larger clips are for those that clip the line where the protective coil is.
I can check for sure tomorrow if needed.
dave
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
post #4 of 5 (permalink) Old Jul 20th, 06, 03:27 AM Thread Starter
ENP
my car is a 69 camaro. I am still needing the info.
thanks
ENP is offline
post #5 of 5 (permalink) Old Jul 21st, 06, 09:44 AM
The reference to the GM Assembly manual is great advice. I bought mine from Rick's 1st Gen. Also check out Inline Tube.com. I believe they have a reference guide also.
nooney is offline
brake line question ce1967 Brakes, Suspension & Steering 4 Jun 15th, 06 06:44 AM
replaceing the hard brake line... jeff_gates Brakes, Suspension & Steering 3 Jun 10th, 06 05:38 AM
Brake line fittings tz1238 Brakes, Suspension & Steering 3 May 20th, 06 11:45 AM
Urgent: Rear Brake Line CFunK Brakes, Suspension & Steering 14 Oct 3rd, 05 10:29 PM
67 fuel line clips SatisTraction Restoration Corner 0 Jul 28th, 05 04:30 PM
