Torque specs? Front end rebuild? - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 15th, 06, 01:34 PM Thread Starter
Guys,
You talked me off the ledge on a rear spring R&R....
What do you torque the shock plate to?
Now the front end
I have the left side ft end torn down on my 69. I am doing a complete ft end rebuild w/ PST rebuild kit. The Ball joints are all original. How do you get all the rivets ground down. I can get to 3 of the 4 heads, but the last one is behind the shaft and the edge of the control arm.
I have a 6ton press. Any tips on getting the old bushings out, and or the new ones in.
greenham is offline
post #2 of 3 (permalink) Old Jul 15th, 06, 02:00 PM
Guess
HwyStarJoe's Avatar
Re: Torque specs? Front end rebuild?
Drill that hidden rivet head out.
The other one's that you already removed will give you a good idea what size drill bit to use.
HwyStarJoe is offline
post #3 of 3 (permalink) Old Jul 15th, 06, 03:29 PM
madmax87's Avatar
Shock plate torque specs depend on what size bolts your using. I got this info from a suspension shop. 3/8-24 = 30lbs, 7/16-20=45lb, 1/2-20=65lb, 9/16-18=90lb, and 5/8-18=120lb. I'm using stock plates on my 69 12 bolt and they use the 1/2-20.
madmax87 is offline
Torque specs for Pinion Nut on rear end Yoke ktaylor36 Transmission & Driveline 18 Oct 3rd, 15 06:01 PM
Ready for front end alignment, questions? ray moore Brakes, Suspension & Steering 10 Jul 5th, 06 06:05 AM
torque Specs cambird68 Engine 8 May 2nd, 06 06:31 PM
Evaluate this launch ron498 Performance 34 Sep 16th, 05 12:03 PM
New Rims-do you have to realign front end? faninc Brakes, Suspension & Steering 2 Jul 18th, 05 11:24 AM
