1967 Power Front Disk - Team Camaro Tech
post #1 of 2 (permalink) Old Jul 17th, 06, 06:50 PM Thread Starter
I just bought a 67 with 4 piston calipers the drivers side is leaking.
1st Q. did the 67 come stock with 4 piston calipers?
2nd Q. can I use a different caliper ? or would I have to change the mounting bracket>
3rd Q. any suggesttions on where to find a caliper rebuild kit?
Thanx for any info
Tim
tcrock is offline
post #2 of 2 (permalink) Old Jul 17th, 06, 07:16 PM
Re: 1967 Power Front Disk
67's only came with the 4 piston calipers. This design is very similar to that used in C3 vettes, and they are very good brakes.
These calipers are made with the rubber on the piston rather than the bore, so once they rust and start to leak, the only viable option is to have the bores stainless steel sleeved. Vettebrakes and other company's do this and sell the reconditioned calipers on exchange. They will also rebuild and return your caliper if you want to stay with "born with"
You could also switch over to the 69 style single piston caliper. These are auto parts atore available and cheap. You'll also need to change the rubber brake hoses, caliper bracket, and backing plate.
Replacement Part Numbers for Steering/Suspension - LONG HwyStarJoe Brakes, Suspension & Steering 14 Sep 16th, 12 10:50 AM
If you convert to disk can you reuse your old power booster, master cylinder etc? ray moore Brakes, Suspension & Steering 6 Jul 7th, 05 06:02 PM
Upgrade to disk brakes and overhaul front suspension at the same time? Granny's 69 Brakes, Suspension & Steering 7 May 6th, 04 04:42 PM
Trunk Lid Fit Problem RPOL72 Body Shop 8 Aug 27th, 03 01:45 AM
67, 68 front disk brake identification? lugnut Brakes, Suspension & Steering 10 Oct 6th, 00 05:45 PM
