disc brake steering arms? - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 17th, 06, 07:03 PM Thread Starter
Chad
Hello guys, if anyone could get me a link to a good used supplier that may have disc brake steering arms that would be great. If anyone has an idea of what they should cost that would be great too. thanks in advance.
67 street strip------------On NOS
NEW BEST july 29/07-----aug 26/06
E.T 11.15----------------10.60
MPH 121.24--------------129.89
60' 1.54------------------1.52
Dec 01/08
Car torn apart soon to be 25.2 cert not sure how fast i want to go
kelemor is offline
post #2 of 4 (permalink) Old Jul 17th, 06, 07:23 PM
Re: disc brake steering arms?
With the exception of the arms used on JL-8 4-wheel disc cars, there aren't really "disc brake" steering arms. The different arm lengths were tied to the type of steering used (manual, power, fast ratio, etc.). David Pozzi has a good discussion on this link, about 2/3 of the way down the page.
http://www.pozziracing.com/camaro_st...eering_linkage
Are you doing a conversion, and think you need new arms? Tell us what you're trying to do and we may be able to better answer.
Eric
Eric Kammerer is offline
post #3 of 4 (permalink) Old Jul 18th, 06, 02:51 PM Thread Starter
Chad
Ok here is what is happening. I bought the car with disc brakes already on but i noticed that the calipers where are the wrong side on rotor (mount towards the front of the car). I should add this car was just a body on wheels when i bought it and most the work that was done was half finished. So i took the car to a buddies shop to get it aligned before taking it to the track last year and everything seemed alright untill i launched the car. As soon as the front tires where unload the right tire toed in bad, when the car came down the tire did a little shimmy then straightend out almost all the way. The car still drives straight but this is not right at all. So a week ago i took the front end apart and what the previous owner has done it seems is put front disc brakes off a chevelle on the car and to make them work mount the disc brake brackets and dust shield on backwards and use the chevelle steering arm. If you have this months copy of chevy rumble the part i need is on the front cover.http://www.mondotimes.com/2/topics/5...nment/11/13576
The fourth little box over from the left above the camaro, if you have the issue in the mag i have the steering arm labeled 64-72 chevelle. I have also noticed that the lower ball joints are junk and that the inner and outer tie rod ends where installed reverse. Iam not sure how much this will change things but iam replacing all of it. I have a manual steering box as well. IF there is anything you need me to add let me know i will answer what i can, thanks for the reply.
Dec 01/08
kelemor is offline
post #4 of 4 (permalink) Old Jul 18th, 06, 09:27 PM
That chevelle arm changes the 'bumpsteer' significantly by raising the tie rod. The susension arc is changing the toe angle. Sounds like you might have idler arm issues too.
You see them on Ebay attached to some brake kits sometimes. Since there are different lengths you want to make sure you have the same on both sides.
I have a pair of long ones I would like to hold on to, but someone here might have an extra set for cheap. Try an ad in the classifieds.
Eric, the JL8 had different arms? I need more info. I've been tossing around ideas of a JL8 front conversion eventually. I pulled a pic from this site and the arm looked the same, except for an extra bolt-on bracket. PM me.
If I didn't learn it from my my mentors, I learned it as a result.
ohcscott is offline
Replacement Part Numbers for Steering/Suspension - LONG HwyStarJoe Brakes, Suspension & Steering 14 Sep 16th, 12 10:50 AM
New 4 wheel disc Brake Problems bl1work Brakes, Suspension & Steering 25 Apr 21st, 06 09:54 AM
14" wheels and disc brake conversion? 68driver57 Wheels & Tires 5 Feb 8th, 06 05:18 PM
10-bolt Rear Disc Brake Axles gheatly Brakes, Suspension & Steering 8 Jan 18th, 06 11:53 AM
shrort steering arms bretcopsey Brakes, Suspension & Steering 3 May 25th, 00 06:15 PM
