Spring lowered car, how about the sway bar - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 22nd, 06, 02:02 PM Thread Starter
Put in 2" drop springs on my 69. Do I have to cut the sway bar end links by 2" as well?
greenham is offline
post #2 of 4 (permalink) Old Jul 22nd, 06, 04:43 PM
Re: Spring lowered car, how about the sway bar
maybe not exactly 2"
ideally the section of the bar that the end link bolts to should be level, i would cut to level the bar, and if it is 2" then you also had it right before
400bird is offline
post #3 of 4 (permalink) Old Jul 22nd, 06, 07:02 PM
David Pozzi
davidpozzi's Avatar
I wouldn't shorten them by more than a half to 1" max. If you go too short, the links will not have enough swing side to side and bind the suspension. Ideally the antiroll bar ends would sit flat when driving but often you can't shorten the end links that much. Don't over torque the end links.
davidpozzi is offline
post #4 of 4 (permalink) Old Jul 22nd, 06, 08:36 PM
Banned
Smile Re: Spring lowered car, how about the sway bar
I re-threaded my Grade-8 end link bolts and cut them so the S/B sat level and then used nuts to locate my Poly pads!
The earlier one's from ADDCO had cheap aluminum tubes for pad washer spacers!! Talk about cheap..
If I had it to do over, I would use Grade-8 bolts but make them so that they are studs so that no threads would be in the pads and use a heavy steel tube or maybe a threadless pipe nipple as a washer spacer!!
And self locking nuts and such too........
pdq67
Should get a sway bar? Car nut Brakes, Suspension & Steering 11 May 11th, 06 06:14 PM
Friend gave me Addco rear sway bar, install it or not? ray moore Brakes, Suspension & Steering 12 Apr 1st, 06 05:16 AM
Sway Bar Interference _PuNiShEr_ Brakes, Suspension & Steering 8 Jan 5th, 06 05:47 AM
Sway Bar installation question? ENP Brakes, Suspension & Steering 3 Dec 11th, 05 08:47 PM
69 front coil spring install ken69 Brakes, Suspension & Steering 6 Nov 1st, 02 06:42 AM
