setting front end ride height - Team Camaro Tech
post #1 of 2 (permalink) Old Jul 22nd, 06, 02:15 PM Thread Starter
I read on here that you should wait till the car was on the ground to tighten everything us, so the car sits right.
It seems that I can tighten the following while on the jack stands
Ball joints
Tie Rod ends
Idler arm
I assume these have to wait till it's on the ground.
Lower control arm
Cross link end bushings
Am I missing something. room is tight under the car when dropped 2"
greenham is offline
post #2 of 2 (permalink) Old Jul 22nd, 06, 04:45 PM
Re: setting front end ride height
sounds like you got it under control
one other thing you should tighten on the ground are the sway bar mounts and end links
400bird is offline
Torque specs? Front end rebuild? greenham Brakes, Suspension & Steering 2 Jul 15th, 06 03:29 PM
lighter motor - want stock ride height thedong Brakes, Suspension & Steering 2 Jun 30th, 06 01:43 PM
69 "Z" front ride height smith69z Brakes, Suspension & Steering 9 Sep 18th, 05 07:32 PM
Power steering problem after front end rebuild BC Brakes, Suspension & Steering 4 Jul 7th, 05 09:15 PM
Uneven ride height on rear end 1968_camaroSS Brakes, Suspension & Steering 6 Apr 29th, 05 07:25 PM
