DUMB Question - Power BRAKE Booster - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 24th, 06, 01:30 PM Thread Starter
Greg
Busy freakin day at work. It's the power BRAKE booster. On the original intake manifold it apparently got vaccuum from the intake manifold but the Crossram manifold doesn't have any place to accommodate. Do I need to find another vaccuum source? Is there any vaccuum inside the valve cover? I could hook it into where the breather cap would go..... Need some help from somebody that knows since obviously I don't Thanks much.........
greg1ontheedge is offline
post #2 of 6 (permalink) Old Jul 24th, 06, 06:27 PM
Re: DUMB Question - Power BRAKE Booster
Might as well us this picture for something,,, Check out the second picture here or hose routing. Is this what you are talking about? http://cgi.ebay.com/ebaymotors/Chevr...QQcmdZViewItem
TC # 349
zdld17 is offline
post #3 of 6 (permalink) Old Jul 24th, 06, 06:30 PM
Well looks like someone beat me to it.... How about a ported hole in the plenum?
TC # 349
zdld17 is offline
post #4 of 6 (permalink) Old Jul 24th, 06, 09:47 PM
john
wagonman's Avatar
yeah, i was wondering about your problem..the crossrams have a vaccum port in them....the thing is......now that your motor is designed and built to accomodate the crossram setup..does it have enough vacuum to run power brakes?
wagonman is offline
post #5 of 6 (permalink) Old Jul 25th, 06, 04:23 AM
Next would be to install a "factory hydro-booster" to work the brakes.
TC # 349
zdld17 is offline
post #6 of 6 (permalink) Old Jul 25th, 06, 06:47 AM Thread Starter
Greg
Re: DUMB Question - Power BRAKE Booster - PICTURE ADDED
Thanks for all the help. I'm very curious about the 'factory hrdro-booster' and where I might get info and buy. There seems to be a bit of confusion about the intake I'm using so I found a picture to clear that up. Again, thanks everybody, for the help.......
http://cgi.ebay.com/ebaymotors/EDELB...11567270QQrdZ1
Manual To Power Brake Question 69Mike Brakes, Suspension & Steering 4 Sep 11th, 05 06:03 AM
Power Brake booster is locking up the brakes denverRS/SS Brakes, Suspension & Steering 7 Sep 3rd, 05 07:39 PM
Power Booster Number Question RonM Tag Team 2 Apr 6th, 05 06:18 PM
power brake booster 69ss350camaro Brakes, Suspension & Steering 2 Dec 7th, 04 03:05 PM
Could an RS Headlight Vacuum Tank be also used for Power Brake Booster ggkeller Brakes, Suspension & Steering 2 Aug 29th, 04 06:26 AM
