4 wheel disc - rears won't lock up - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 31st, 06, 01:34 PM Thread Starter
I just finished a 4 wheel drum to 4 wheel disc conversion. The master cylinder was already in the car when I bought it, it is from a vette with 4 discs, but not sure of the year. I am still using the original distribution block. EVERYTHING else is new, including every brake line. With the car up on jack stands, I can't get the rear wheels to lock up with the car in drive. Must I use an adjustable proportioning valve? Here's a list of what I have already eliminated:
Blead like hell (also blead the brakes a lot)
parking brake is adjusted
I have the right push rod behind the MS (fluid blows up both ports with the MS cover off)
Any ideas on what I should try next?
hybryd67 is offline
post #2 of 5 (permalink) Old Jul 31st, 06, 03:04 PM
David Pozzi
davidpozzi's Avatar
Re: 4 wheel disc - rears won't lock up
We need to know exactly what the brakes are from, a Corvette? What year? Stock? Aftermarket? Baer?
davidpozzi is offline
post #3 of 5 (permalink) Old Jul 31st, 06, 04:33 PM Thread Starter
Both the front and rear kits are aftermarket for a 67 Camaro, bought new on eBay, nothing fancy or expensive. I was under the impression both of these kits are close to original specs.
hybryd67 is offline
post #4 of 5 (permalink) Old Jul 31st, 06, 05:33 PM
Charles
try bleading the rear brakes at the flex line from the body to the rear axle. usually it is looped up and you could have an air bubble trapped up there in the rubber hose that's not making it's way down to the rear cylinders. you should get a solid stream of fluid out of all 4 cylinders.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #5 of 5 (permalink) Old Jul 31st, 06, 07:12 PM
David Pozzi
davidpozzi's Avatar
What calipers do they use? What are the rotor diameters?
Are the calipers stock iron, or aluminum like from a late Camaro or Corvette? It makes a huge difference, since the early iron calipers need a 1 1/8" bore master cyl, the later calipers need a 7/8" or so.
I still don't have enough info to help you.
Master Cly for 4 wheel disc ??? gene_sc Brakes, Suspension & Steering 2 Jun 13th, 06 08:05 AM
68 Wheel Codes - Disc Front XG - What Rear? aburgess Restoration Corner 8 Nov 9th, 05 06:43 AM
OOPS ? 4 wheel disc brake claim , I wonder? click Bench Racing 6 Feb 25th, 04 01:22 AM
Door Lock Problem Michigan67Vert Body Shop 5 Jul 1st, 03 04:23 AM
sizes from Chevy High Performance article michaelm5 Wheels & Tires 10 Jan 16th, 03 02:53 PM
