leaf spring pads - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 1st, 06, 03:43 PM Thread Starter
Russ
leaf spring pads
I just received my new poly leaf spring pads. Now heres the delima .The pads are 1/2" thick of course there is two required thats a total of one inch , the 5 multi leaf springs that are already on the car are 1 1/2" thick and the perch pocket on the rear is only 2 1/16" deep.that's almost a 1/2" difference! Are those poly pads going to squeeze enough for the shock plate to meet the spring perch after the bolts are tight? Im thinking not because thats just my luck.
Russ
19694speed is offline
post #2 of 8 (permalink) Old Aug 1st, 06, 05:04 PM
Banned
Re: leaf spring pads
Heck, I think mine are only like 3/16" to maybe a 1/4" thick and they had lips that were on each side that were like an 1/8" tall or so that I had to trim off CAREFULLY by hand using a sharp boxknife.
pdq67
post #3 of 8 (permalink) Old Aug 1st, 06, 06:23 PM Thread Starter
Russ
Wow could be the wrong pads.Does anyone know how deep the spring perch pocket is supposed to be on a 69 12 bolt w/ multi leaf? Mine currently is 2 1/16" from where the top pad sits to the bottom where the shock plate mounts . It has the 5 leaf set up in there now , should it only be 4 leaf , are they thinner? As stated above the 5 leaf are 1 1/2' thick.
Russ
post #4 of 8 (permalink) Old Aug 6th, 06, 10:18 AM Thread Starter
Russ
Does anyone have thier rear out that could take a measurement of the spring perch pocket for me? Hmmm that dont sound right.
Russ
1969 RS conv,hugger orange,396 4 speed,373 12 bolt posi.
post #5 of 8 (permalink) Old Aug 6th, 06, 11:35 AM
Greg
I am going through all of this right now..I will try to rememer to measure the perch depth.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, 9:1, 10 PSI, Water/Meth injection
1.325 60', 5.988 @ 115.4 (carb)
Switched to Super Sniper EFI 2019
Greg O is offline
post #6 of 8 (permalink) Old Aug 6th, 06, 01:05 PM
Greg
Just got out from under the car...your measurement is correct. Mine is a 5 leaf car and is about 2" deep. I ran the poly pads just fine. I just squished them a bunch to get the shock plate up there.
Greg O is offline
post #7 of 8 (permalink) Old Aug 6th, 06, 03:14 PM
Andy
You technically don't HAVE to use any pads at all back there. I've talked to a lot of people who've run with and without them and said there's no difference that could be noticed while driving. Just my .02.
Drive it like a stolen rental!!!
Powered By Winchester is offline
post #8 of 8 (permalink) Old Aug 6th, 06, 04:49 PM Thread Starter
Russ
Thanx I'll give a shot. I did'nt think the poly would squeeze that much.Its quite a relief knowing that the perches are the same size as yours. Thanks again for taking the time to measure that for me
Russ
Leaf spring pads and pinion angle ept000 Brakes, Suspension & Steering 4 Jan 25th, 06 01:53 PM
Please post pics of your cars' stance after new leaf springs poloz28 Brakes, Suspension & Steering 29 Mar 11th, 04 08:58 AM
hotchkis leaf spring pads kilo_00 Brakes, Suspension & Steering 14 Mar 7th, 04 03:45 AM
Solid or Aluminum Leaf Spring Pads??? camaroman7d Brakes, Suspension & Steering 2 Feb 3rd, 04 09:36 AM
leaf spring to axle pads '69 ss 396 mike brown Brakes, Suspension & Steering 3 Nov 23rd, 99 07:15 PM
