Anyone know where I can get Landrum Spring Adjusters - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 4th, 06, 04:50 PM Thread Starter
I love the idea of being able to adjust the front end like this vs cutting
greenham is offline
post #2 of 5 (permalink) Old Aug 4th, 06, 05:36 PM
David Pozzi
davidpozzi's Avatar
Re: Anyone know where I can get Landrum Spring Adjusters
go here:
http://www.speedwaymotors.com
search for:
91645552
davidpozzi is offline
post #3 of 5 (permalink) Old Aug 4th, 06, 05:42 PM Thread Starter
Whats your opinion Dave. Its a 69 coupe fro Sunday cruising. I wanna use it to dial in ride height.
Originally Posted by davidpozzi
go here:
search for:
91645552
greenham is offline
post #4 of 5 (permalink) Old Aug 9th, 06, 09:50 AM
I have them, but a pain adjusting try Tyler at ATS he has a modified version
that makes adjusting them easier.
19topless69 is offline
post #5 of 5 (permalink) Old Aug 9th, 06, 11:16 PM
David Pozzi
davidpozzi's Avatar
That's the problem, they are hard to get to.
I've seen the threaded adjuster ring welded into the subframe top, then a bar welded across the adjuster tube, with a hole in the center for the shock to bolt into. The whole adjuster with shock can be screwed up or down. You have to make a tool to grab the adjuster. This requires tubular upper arms.
Please post pics of your cars' stance after new leaf springs poloz28 Brakes, Suspension & Steering 29 Mar 11th, 04 08:58 AM
69 front coil spring install ken69 Brakes, Suspension & Steering 6 Nov 1st, 02 06:42 AM
Is there a Difference Between Afco and Landrum Spring Adjusters JR69Camaro Brakes, Suspension & Steering 2 Sep 25th, 02 03:12 PM
Landrum spring adjusters... quick! Ripper Brakes, Suspension & Steering 3 Jul 27th, 02 11:51 PM
Landrum spring adjusters jmar Brakes, Suspension & Steering 14 Jul 18th, 02 05:36 PM
