Front wheel bearings - Team Camaro Tech
post #1 of 12 (permalink) Old Aug 5th, 06, 06:38 AM Thread Starter
Bill
Kind of an odd question...
Does anyone know what type of wheel bearings Ground Up sells? I ordered some from Rick's and they are imported Chinese ones. I've had great luck with Timken stuff and would like to stick with them if I can.
Also, am I overreacting? Chances are this car will see some open track days and I don't want to cheap out on bearings if it really matters.
WildBillyT is offline
post #2 of 12 (permalink) Old Aug 5th, 06, 08:04 AM
Re: Front wheel bearings
I would also stick with Timken I have them on my car and have used them for years. Not a high $ item but it sucks when they go. I think Napa has them.
dmundell68 is offline
post #3 of 12 (permalink) Old Aug 5th, 06, 10:57 AM
Banned
Mine are Toyo's from Japan and I have read where they are FINE!!
My first reaction after seeing the name "Toyo" on their boxes was, "Here I go again!!" But I didn't have to..............
pdq67
post #4 of 12 (permalink) Old Aug 5th, 06, 11:00 AM
Carl
Timken, SKF, and NSK are likely the most popular brands carried by the good resellers. The cups and cones from these manufacturers are interchangeable.
There is some Chinese stuff out there but I would recommend staying away from them. If you go into Lowes or Pep Boys check out the trailer section. They will have them packaged for trailer repairs since they are the same parts. Most are made by Peer, a Chinese manufaturer/importer. In an emergency, broken down in BFE, they will work fine as a temporary measure.
You can also buy the bearings from an idustrial distributor such as Motion Industries, Kaman Industrial Technologies, and Applied Industrial Technologies. These companies will likely be selling only Timken products since they dominate the industral aftermarket for tapered roller bearings. These sizes are also very commonly used in industry. I would stay away from McMaster Carr for these parts since they have a much different inventory and purchasing system.
You will need the following part numbers:
Inner: LM67010 cup, LM67048 cone. May be listed as LM67010/910 for a cup and cone assembly. Also known as a Set #6 or A6. You will need two of each.
Outer: LM11910 cup, LM11949 cone. May be listed as LM11910/949 for a cup and cone assembly. Also known as a Set #2 or A2. You will need two of each.
You will also need two pcs. Federal Mogul P/N 8705S inner hub seals. Timken now owns National Seal Company so there's a good chance you may get a "Timken" seal.
Paul,
Your's were Koyo's, who is owned by Toyota. They are a pretty good part as well. They are likely #2 or #3 in the U.S. for automotive aftermarket inch series tapers. The anti-dumping regulations for Japan and Sweden (NSK/Koyo and SKF) keep the prices artificially high in the United States, to the benefit of Timken but at the cost of the higher consumer prices.
CarlC is offline
post #5 of 12 (permalink) Old Aug 5th, 06, 03:08 PM
Steps
We have several 'budget' trade wholesalers here selling Chinese bearings..All makes of cars..imports etc
They are crap.
Stick with brands recomened above thu SEACO should be added to the list of good
Steptoe is offline
post #6 of 12 (permalink) Old Aug 5th, 06, 03:16 PM
Carl
Steptoe,
Isn't SEACO a "down under" distribution channel, not a manufacturer?
CarlC is offline
post #7 of 12 (permalink) Old Aug 5th, 06, 04:34 PM Thread Starter
Bill
Paul,
Wow Carl, thanks for the great reply!
The stuff I have is "PTC" Power Train Component brand. Branded out of Ohio but made in China. I think I'm going to return it for better quality stuff.
post #8 of 12 (permalink) Old Aug 5th, 06, 09:24 PM
Steps
Ste
ptoe,
Yeah, stand corrected...and they are expensive to lol
Steptoe is offline
post #9 of 12 (permalink) Old Aug 6th, 06, 07:00 AM
Banned
Carl,
They were cheap enough to me when I got them.
Go figure? I got them from O'Reilley's(Sp?)...
pdq67
post #10 of 12 (permalink) Old Aug 6th, 06, 05:24 PM
i purchased an aftermarket front disc kit with "ntn" u.s.a. bearings,are these a quality bearing??
built4spd is offline
post #11 of 12 (permalink) Old Aug 7th, 06, 03:27 AM
Yes.
post #12 of 12 (permalink) Old Aug 7th, 06, 07:52 AM
Carl
Years ago NTN purchased all of the Federal Mogul and BCA plants, so if it says NTN USA, it came from one of those plants. It will be fine.
CarlC is offline
Ever wonder what happens when your front wheel falls off and passes you? davepl Bench Racing 39 Mar 19th, 06 01:55 PM
Front wheel backspacing ahmanns Wheels & Tires 3 Dec 31st, 05 09:15 AM
Front Wheel fitment on '79 camaro wizard67 Wheels & Tires 1 May 3rd, 05 10:36 PM
front wheel camber sick67 Wheels & Tires 1 Feb 23rd, 05 01:13 PM
wheel bearings bruce69camaro Brakes, Suspension & Steering 9 Apr 2nd, 03 02:57 PM
