Which steering arm? - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 6th, 06, 10:46 AM Thread Starter
Vince
Which steering arm?
I am installing a 69 power steering box on my 67 and was wondering which arm I should use. Car was manual steer prior to this. Did a search with no luck, any help would be great. Go Jeff Burton!
3forme is offline
post #2 of 4 (permalink) Old Aug 6th, 06, 10:56 AM
Banned
Re: Which steering arm?
You will need a power steering arm b/c the manual arm's hole is too small!
As for arm, I used the long one along with my short bolt-on spindle arms! I wanna say, 5.75" long vs the short at say a schosh over 5"???
You might check over on David Pozzi's great site and see if he has the actual lengths of them.
David has a wealth of info over there!!!!!!!!!!!!!!!!!!!!!! Good reading.....
pdq67
post #3 of 4 (permalink) Old Aug 6th, 06, 11:11 AM Thread Starter
Vince
That was quick, thanks. What do you mean "short" spindle arms. I was going to use stock 67 disc spindles. I checked Davids site couldn't find it, I'll give another look. Did this conversion 15 years ago I cannot remember what I did back then on diff. 67.
Thanks again
3forme is offline
post #4 of 4 (permalink) Old Aug 6th, 06, 12:05 PM
if you're swapping to power from manual now, you must use a power steering pitman arm. Commonly available arm now is a moog, 5.35" long.
If you want "faster" steering, a longer pitman arm and / or shorter steering arms at the wheels will quicken the steering ratio.
Note that depending on the steering box you are using, there can be too much of a good thing, a thirdgen box would be too twitchy with both the long pitman arm and the short steering arms, but is perfect with the short pitman and medium or long steering arms.
Replacement Part Numbers for Steering/Suspension - LONG HwyStarJoe Brakes, Suspension & Steering 14 Sep 16th, 12 10:50 AM
Steering Column reassembly Steptoe Camaro Tech 17 Jan 23rd, 07 08:48 PM
mismatched pitman arm and steering box help cm-67 Brakes, Suspension & Steering 2 Jun 11th, 06 07:48 PM
Front end kit in Canada Mark Yetman Brakes, Suspension & Steering 19 Mar 14th, 04 01:27 PM
Suspension Parts List davidpozzi Brakes, Suspension & Steering 3 Feb 23rd, 04 01:54 AM
