braided brake lines - Team Camaro Tech
post #1 of 12 (permalink) Old Aug 7th, 06, 09:23 PM Thread Starter
Ed
braided brake lines
Anyone know where I could get a complete set of braided brake lines?
Ed
mred91316 is offline
post #2 of 12 (permalink) Old Aug 7th, 06, 09:56 PM
gramps68's Avatar
Re: braided brake lines
try Earls...http://www.holley.com/types/Hyperfir..._Line_Kits.asp
Anything worth doing is worth overdoing...a little's good, more's better, and too much is just enough
68 rs - Van Nuys original - one family car.....which still needs to be finished!
gramps68 is offline
post #3 of 12 (permalink) Old Aug 7th, 06, 10:05 PM
Harley D
HarleyD67's Avatar
Summit sells a set from Russell. The only thing is the 67-69 kit only fits disk brake carsnot drum. Found out the hard way.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #4 of 12 (permalink) Old Aug 8th, 06, 08:25 AM Thread Starter
Ed
I need lines for a 1967 with drum brakes all around. Ricks sells them for around $24 and when you add in the shipping cost $13, it comes out to about $37. A set of four will run me about $ 120. Anyone have a cheaper place?
post #5 of 12 (permalink) Old Aug 8th, 06, 08:33 AM
And to add to this, when they say "Drum Brakes," ask them "For sure?"
Even drum brake hoses don't fit drum brake cars, or for anything else.
Summit was nice enough to return & refund.
post #6 of 12 (permalink) Old Aug 8th, 06, 08:44 AM
Mike_M's Avatar
Send a message via MSN to Mike_M
Inline Tube (www.inlinetube.com) has them for $95 - not sure what the shipping would be. I just ordered a bunch of stuff from them and they were very helpful on the shipping.
Mike...
Mike_M is offline
post #7 of 12 (permalink) Old Aug 8th, 06, 09:21 AM Thread Starter
Ed
I just called Inline tube and they only want $10.58 to ship. Not bad.
Thanks.
post #8 of 12 (permalink) Old Aug 8th, 06, 01:34 PM
David Pozzi
davidpozzi's Avatar
Why put braided hoses on drum brakes???
There is no benefit to braking, drums have much less line pressure. Stock hoses will work very well for drum brakes.
davidpozzi is offline
post #9 of 12 (permalink) Old Aug 8th, 06, 01:38 PM
Vintage 68's Avatar
Question Re: braided brake lines
Thank you for asking that David - other curious minds would like to know also...
Can't be just for show
1968 Convertible
Some trucks
Vintage 68 is offline
post #10 of 12 (permalink) Old Aug 8th, 06, 03:01 PM Thread Starter
Ed
Smile Re: braided brake lines
I though they would work better and everyone says that they eliminate spongy pedal feel and stop in a shorter distance. That why. If that's not the case, then stock hoses it is, there cheap anyways. That's why I asked and respect your feedback.
post #11 of 12 (permalink) Old Aug 8th, 06, 04:01 PM
Carl
I agree with David.
For a stock drum/drum or disk/drum the stock brake lines work fine. The line pressures for these systems is about 60% of what most modern systems require, and they too work fine with OEM rubber lines. If the brake system is in good condition and properly bled the limiting factor is not the brake lines, it's the tires.
Braided lines are useful on custom applications where different lengths and/or ends are needed. Since I run AN fittings for everything finding rubber hoses is tough.
CarlC is offline
post #12 of 12 (permalink) Old Aug 8th, 06, 04:29 PM Thread Starter
Ed
Thanks for your feed back.
New brake lines, Stainless or original? Liveinaz Brakes, Suspension & Steering 10 Jan 10th, 06 02:18 PM
Brake Lines after swap twshelton Brakes, Suspension & Steering 7 Aug 22nd, 05 07:13 PM
Brake Lines Suck!!! mark67ss Brakes, Suspension & Steering 16 Jul 20th, 05 04:55 AM
Brake Bleeding the right way WillS Brakes, Suspension & Steering 0 Feb 14th, 05 03:45 PM
I need routing brake lines shadow53 Brakes, Suspension & Steering 4 Jan 22nd, 02 03:54 AM
