front tire wear - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 12th, 06, 07:19 PM Thread Starter
front tire wear
Today I parked with my wheels turned and just happened to glance at the front rubber at a new veiw.
I have severe wear on the inside edge of both tires, maybe the first inch is worn really bad.
Guldstrand mod suspension has been together and untouched for 4 or 5 years, about 12k miles, front tires are 225-50-16. Car was aligned at this ride ht with these tires when I purchased the tires.
Alignment specs are 3.5 pos caster, 1 neg camber, 1/16" toe.
What can I do to stop this wear?
Take some of the camber out?
I need 1 more season out of these tires. No rotation, unidirectional tread and different sizes front/rear.
post #2 of 5 (permalink) Old Aug 12th, 06, 08:05 PM
Harley D
HarleyD67's Avatar
Re: front tire wear
Jim did you recheck the alignment specs. I mean I know you just did the Run to the Rockies and that 1500 mile "test drive" before that. Is it possible something came loose? Maybe you hit a curb or pothole and knocked something out of alignment.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #3 of 5 (permalink) Old Aug 12th, 06, 09:19 PM
Re: front tire wear
1 degree negetive camber will give you some inside tire wear. I run 1/4 to 1/2 degree negetive camber and still get slight inside wear. Why do you run so much negetive camber on a street car? I agree you should get the alignment checked again.
badboy is offline
post #4 of 5 (permalink) Old Aug 13th, 06, 07:43 PM
BonzoHansen's Avatar
Re: front tire wear
Realign it and drop the camber to -1/2". Go closer to 0* toe. A little toe out & too much negative camber will do that.
TC Member #13
BonzoHansen is offline
post #5 of 5 (permalink) Old Aug 13th, 06, 11:01 PM
Steps
Re: front tire wear
My son just sat down beside me as I pulled this thread up
Hes a tyre/wheel alignment guy
1 neg camber
His comment "thats stuff all, will not make any diiff"
1/16" toe.
Again "thats stuff all, will not make any diiff" "set the toe to zero"
How sure are u the alignment machine is regularily calibrated?
These are the specs I used for many yrs
Left camber 0.33 deg
right camber 0.33 deg
caster 2.0 deg
Total toe O.5mm
This was used for daily driving, town and highway...gave a quite a light steering good around town/ highway crners tended to push ....
tyre wear excellent
My current setup
Toe left and right 0.7mm
Total Toe 1.4mm
caster left 3 deg 26 min
caster right 3 deg 03 min
camber left 1 deg 9 min
camber right 1 deg 16min
This also works well with great improvement for highway cnring and around town good to
Keep in mind this is a Left hook (factory)car driven on left hand drive roads in NZ.
Driver next to the kerb
Steptoe is offline
what front tire to mate with BF comp t/a on rear sick67 Wheels & Tires 0 Jul 6th, 05 09:27 AM
need front tire size with Gulstrand ochrisl Brakes, Suspension & Steering 9 May 28th, 03 11:04 AM
Hood adjustments!! Handy69Z Body Shop 2 Mar 13th, 03 04:14 AM
Hanging Doors ? wesley58_do Body Shop 6 Jan 30th, 02 11:23 AM
