Mini tub w/Hotchkis springs - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 13th, 06, 04:53 AM Thread Starter
Hey guys, I've been away for a while but it's now time to drag the cover off my 67 and start building again. I am having a hard time trying to decide how far I want to go with this build. I have already rebuilt all the suspension with a TVS kit and poly bushings front & rear. Now I am considering a mini tub but need some confirmation that my Hotchkis springs will work with the DSE kit.
Also, to what length will i need to cut my rear end to. I may upgrade to a 12bolt and will most likely maintain drums in the rear.
Thanks,
Brandt
1970 Nova 350/alum. heads/650 holley/373 11.03 et w/100 shot
1967 Camaro
lite em up is offline
post #2 of 2 (permalink) Old Aug 13th, 06, 11:33 AM
Re: Mini tub w/Hotchkis springs
As far as I know you can use your springs but you have to weld new spring perches.
You can order a wheel with the right backspacing for your rear or better yet get the wheel you like and build your rearend around it
67 LS1 T56
67ptcamaro is offline
To mini tub or not to 67RS RAG Brakes, Suspension & Steering 13 Jan 6th, 09 06:09 AM
68 Trunk floor mini tub? Bigstick1973 Body Shop 3 Apr 23rd, 06 08:21 AM
Mini Tub Kit, how low should I go? curtis26 Brakes, Suspension & Steering 6 Mar 30th, 06 10:10 PM
To mini tub or not to mini tub. That is the question. q2quest Brakes, Suspension & Steering 13 Feb 3rd, 06 10:12 AM
Mini Tub Kit Muscle Mad Body Shop 8 Jan 31st, 06 01:14 PM
