Power Steering Noise - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 13th, 06, 09:22 PM Thread Starter
Bob
I took the camaro out for a spin around the block today and stopped at a buddies to help him with his 66 Mustang. While I was turning out of the driveway the steering wheel was at full lock and I was getting a hi pitched squeel. It didnt sound like a belt. I jacked up the front end and took the cap off of the pump and turned lock to lock. Fluid was full and I dint notice any air bubbles. Any ideas??
Bob
69vert is offline
post #2 of 5 (permalink) Old Aug 14th, 06, 07:53 PM Thread Starter
Bob
Re: Power Steering Noise
bump
69vert is offline
post #3 of 5 (permalink) Old Aug 14th, 06, 09:10 PM
Paul
MCGOO's Avatar
High pitch makes me think belt.
Check the tension & maybe use a bit of belt dressing on it, or a file on the edge.
Paul
'69 Camaro, 250 inline 6, EFI Turbo rebuild is running!!
, CC5S TKO 500, and more.
V8 Camaros are like navels......Everybody has one.
The Toad. 1970 base Camaro (Navel), 350, turbo 700R4, 3.73 posi, Hotchkis TVS system,
Mrs. McGoo's & McGoo Jr.'s toy
MCGOO is offline
post #4 of 5 (permalink) Old Aug 14th, 06, 09:15 PM
Lester
I think thats normal. Did the sound stop when you let the pressure off full lock?
Les Dixon member #68 1968 camaro RS/SS MR code L34 396 air convertible
mr396 is offline
post #5 of 5 (permalink) Old Aug 15th, 06, 08:46 PM Thread Starter
Bob
Yes the sound stops when you release from full lock. It is annoying, but just want to make sure nothing is wrong with the pump.
Bob
69vert is offline
Power Steering And Header Clearence JAKER110 Brakes, Suspension & Steering 8 Jul 20th, 05 04:00 PM
Twitchy 3rd gen power steering box Midnight68 Brakes, Suspension & Steering 7 May 26th, 05 05:31 PM
Power Steering / Belt Alignment Problem kgaffney Tech 2000 17 Jul 9th, 01 04:36 PM
Power steering pump noise??? nrowland Troubleshooting 1 Jan 30th, 01 09:36 AM
Power steering problems!!! dustys Troubleshooting 5 Mar 10th, 00 11:26 AM
