ride height - Team Camaro Tech
post #1 of 19 (permalink) Old Aug 15th, 06, 11:10 AM Thread Starter
ride height
i have a 69 z28. complete restoration. i noticed the front seemed a little lower than it should be so i changed the springs with factory spec ones. after installation i have driven the car occasionally and i recently noticed that it sits a little lower again in the front. any ideas?
thank you
barry
biil9 is offline
post #2 of 19 (permalink) Old Aug 15th, 06, 01:01 PM
Welcome Back - Senior Tech
Re: ride height
How much are we talking? If its 1/2 to 2" all your seeing is the spring settling into its pocket. This is no big deal and occurs naturally. My Eibachs have settled an inch since I put them in.
bearcat44 is offline
post #3 of 19 (permalink) Old Aug 15th, 06, 02:35 PM
Doug
thedugan's Avatar
Send a message via Yahoo to thedugan
Re: ride height
Which spring did you install
-Doug
68 RS/SS Conv
67 Coupe
thedugan is offline
post #4 of 19 (permalink) Old Aug 15th, 06, 02:36 PM
Johnny
Re: ride height
Did you check your 1969 camaro assembly manual for the correct height?
67Camaro 396BB 750Holley, edlebrock performer,280isky,3.42 posi, turbo 350,stage 2 shift kit, 2800 stall, MSDready to run distributor, headers, 2.5"exhaust, Hotchkis(1.5"/2"drop).(orig.Deep water blue/light blue dlx inter, v8 column shift/bench seat)
johnny67 is offline
post #5 of 19 (permalink) Old Aug 15th, 06, 06:15 PM Thread Starter
Re: ride height
that would be about right. i will check my assembly manual for the correct height although i think it was on spec once i installed the springs. thank you for your reply
biil9 is offline
post #6 of 19 (permalink) Old Aug 16th, 06, 03:47 PM Thread Starter
Re: ride height
the book says 27" from the ground to the wheelwell. mine measures 24. it was the right height after i installed them. any other reason for the excessive drop. the profile of the car just isn't right at this height. that was the reason for the change in the first place.
thank you for your time
barry
biil9 is offline
post #7 of 19 (permalink) Old Aug 16th, 06, 03:49 PM
Johnny
Re: ride height
what size are your tires and rims?
johnny67 is offline
post #8 of 19 (permalink) Old Aug 16th, 06, 03:49 PM Thread Starter
Re: ride height
i used the chart from ricks to determine what spring was right for my car. it was fine when i installed them but the drop has been 3 inches.
biil9 is offline
post #9 of 19 (permalink) Old Aug 16th, 06, 03:52 PM Thread Starter
Re: ride height
15 rally's. factory correct goodyear poly gt's. boy do they suck.
biil9 is offline
post #10 of 19 (permalink) Old Aug 16th, 06, 03:54 PM
Johnny
Re: ride height
did you call Ricks and ask them for assistance?
johnny67 is offline
post #11 of 19 (permalink) Old Aug 16th, 06, 05:51 PM
Doug
thedugan's Avatar
Re: ride height
what do you have in the back. tire size, new leaf springs? What is the rear ride height.
-Doug
68 RS/SS Conv
67 Coupe
thedugan is offline
post #12 of 19 (permalink) Old Aug 17th, 06, 06:23 AM Thread Starter
Re: ride height
no not yet.
biil9 is offline
post #13 of 19 (permalink) Old Aug 17th, 06, 06:33 AM Thread Starter
Re: ride height
multi leaf rear. e-70-15 polyglas. rear to wheel lip 261/2.
biil9 is offline
post #14 of 19 (permalink) Old Aug 17th, 06, 05:54 PM
JohnZ's Avatar
Re: ride height
barry
There is no GM spec for ground to wheel well lip; front ride height is checked by measuring the difference between the two points shown in the Assembly Manual in UPC 0, Sheet A10, Trim Heights. Were the springs installed correctly seated in the frame pocket at the top?
JohnZ
CRG
JohnZ is offline
post #15 of 19 (permalink) Old Aug 17th, 06, 06:02 PM
Guess
HwyStarJoe's Avatar
Re: ride height
Did a past owner install 2" drop spindles?
HwyStarJoe is offline
New leaf spring ride height Greg O Brakes, Suspension & Steering 3 Aug 4th, 06 03:33 PM
lighter motor - want stock ride height thedong Brakes, Suspension & Steering 2 Jun 30th, 06 01:43 PM
Ride height on repro leaf springs John3366 Brakes, Suspension & Steering 27 May 24th, 06 07:37 PM
Ride Height 69TPI383 Brakes, Suspension & Steering 14 Dec 30th, 01 09:42 AM
SSM liftbars - ride height camaro-69ss Brakes, Suspension & Steering 2 Mar 26th, 01 01:23 PM
