Question on rear spring perch/shock plates, multi-leaf - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 15th, 06, 10:43 PM Thread Starter
Chuck
Send a message via AIM to ChuckD Send a message via MSN to ChuckD
Question Question on rear spring perch/shock plates, multi-leaf
Hey gang.......just put the rear suspension back in after being out for over a year. I replaced only the cushion pads. Question is this....should the shock plate and the perch/spring mount on the axle clamp tight together when the u-bolt and t-bolts are tightened up, or should there be a gap? On the drivers side, there was a gap. On the passenger side, I was able to close the gap completely. I will go back to the other side tomorrow and re-visit my work, as I loosened it all up again on the drivers side, but thought I should ask the question..........gap or up tight? Car is a 69 Z with 5 leafs, stock plates and 12 bolt rear.
69 Z-28-Glacier Blue, X-77
ChuckD is offline
post #2 of 4 (permalink) Old Aug 15th, 06, 11:24 PM
Send a message via AIM to RamAirDave
Re: Question on rear spring perch/shock plates, multi-leaf
If the rear end has multi leaf perches on it, then they should close up tight. Many times you see multi leaf springs on a mono leaf perch axle, and there will be a gap.
Check the side with the gap and make sure the cushions are where they need to be, and that theyre not bunched or binding up.
dave
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
post #3 of 4 (permalink) Old Aug 16th, 06, 09:14 AM Thread Starter
Chuck
Thanks Dave.......I think due to the fact the spring are in full arch, they do not clamp up flat until I put weight on them. I think that will help. Once I do that, I will re-torque all rear suspension fasteners. If I have any more problems, I'll let you know. Thanks again!!
ChuckD is offline
post #4 of 4 (permalink) Old Aug 17th, 06, 11:18 AM Thread Starter
Chuck
Once I lined everything up, and tightened in sequence, using a gun, it all came together. Just make sure the cushions are not folded up and are aligned properly, then all is good.
ChuckD is offline
rear leaf spring problem d's 68 Brakes, Suspension & Steering 7 Jul 17th, 05 12:26 AM
rear axle leaf mount government10 Transmission & Driveline 8 Dec 31st, 04 05:44 PM
mono vs multi anchor plates ramcda Brakes, Suspension & Steering 2 Mar 25th, 03 01:41 AM
MONO TO MULTI LEAF SPRING SWAP BARRY Tech 2000 5 Jul 1st, 00 05:51 PM
