Rear Brake Drum Question - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 18th, 06, 08:28 AM Thread Starter
Bill
my second project car is a '52 chevy pickup street rod. it was converted to front disc brakes with rear drums sometime in the past.
i'm rebuilding the rear drum brakes but can't find any p/n's on the rear axle assembly. so i'm not sure what vehicle this specific 10 bolt rear came in.
the rear drums are 9.5 x 2.00 finned drums, with a 4.75 bolt circle.
i believe that these would also be stock drums on the '69 camaros.
is that correct? does the '69 also use a 4.75 bolt circle??
thanks
bill
Bill
1969 Camaro RS Convertible, 350/700R4, front disc brakes,8.5 10 bolt rear w/ 3.73 posi
1999 Camaro Z28 m6 345K miles
billscamaros is offline
post #2 of 4 (permalink) Old Aug 18th, 06, 09:49 AM
Bob
Re: Rear Brake Drum Question
Alot of guys use an S-10 chassis with those older trucks. My son has a 53 chevy sitting on an S-10 chassis. Frankenstein as I like to call it. I think a 10 bolt rear is too wide for those old trucks. Good luck.
Bob
69vert is offline
post #3 of 4 (permalink) Old Aug 18th, 06, 11:04 AM Thread Starter
Bill
i've seen several threads about guys using the s-10 chassis under older trucks. but this is an original chassis with a nova subframe welded into the front. just picked this up last weekend, and have to get the rear brakes set before i want to drive it much.
Bill
post #4 of 4 (permalink) Old Aug 18th, 06, 11:11 AM
Vintage 68's Avatar
If you get the Casting numbers and date from the center section along with the axle assembly code (they are hard to see sometimes) from the front passenger side of the axle tube you should be able to decode it's origin.
If all else fails, you can contact 'big gear head' Fred on here and he can help you fiqure out the correct parts for it.
1968 Convertible
Some trucks
Vintage 68 is offline
Rear brake cylinder question. supv26 Brakes, Suspension & Steering 10 Oct 30th, 04 04:04 AM
67-12 Bolt rear drum brake pics Fast67 Brakes, Suspension & Steering 2 Mar 27th, 04 01:42 AM
rear disc brake question tvgreen Brakes, Suspension & Steering 3 Nov 2nd, 03 05:29 AM
rear drum to disk conversion question 130fe Brakes, Suspension & Steering 11 Aug 20th, 02 11:57 PM
