67 hub diameter? - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 19th, 06, 07:32 PM Thread Starter
67 hub diameter?
i have a 1967 RS with disc brakes and i need to replace them because of a problem with the hub. well i have been looking of replacement ones but the ones i have found say they are a dia. of 5 3/4" or 6 1/2" hub. well i measured my hub and it looks to me like it should be around a 6" dia. im not sure if im not measuring it right or what. does anyone know what the diameter is? the wheels on my car are 14" stamped DA. thanks
CamaroSS00 is offline
post #2 of 3 (permalink) Old Aug 19th, 06, 08:36 PM
Re: 67 hub diameter?
you could check ebay and use the ask the seller a q' option i've seen these brakes going on there before. just an idea.
impreza13 is offline
post #3 of 3 (permalink) Old Aug 20th, 06, 08:14 AM
Banned
Smile Re: 67 hub diameter?
If your disc brakes are stock, then you need a 2-piece rotor hub OR onna the new 1-piece cast rotor hubs to use with 4-piston calipers.
This is b/c the 4-piston caliper pads are radially wider than the single piston caliper pads so the hub has to be smaller in overall OD so the rotors OD still remains the same.
The later '69 one's use the big single piston calipers so are different b/c the hub OD is bigger around.
pdq67
Anti Theft System for Rally Hub Caps? Camaro Dave Wheels & Tires 4 May 16th, 06 10:13 AM
Pictures of correct OEM Gills, lights, 67, 68 Camaros ToyzShopGary Body Shop 5 Jan 15th, 06 07:26 AM
67 "later model" calipers rodek Brakes, Suspension & Steering 7 Dec 31st, 05 11:01 PM
New Rally Rims-with different size center hub? faninc Wheels & Tires 9 Jul 3rd, 05 11:41 AM
