Strange sound after disk brake conversion - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 19th, 06, 10:53 PM Thread Starter
Question Strange sound after disk brake conversion
I just had my front drums replaced with a disk conversion kit from Mattís Classic Bowties. The brakes are made by CPP. The brakes are fine but I noticed when driving down the freeway, if I hit a good sized bump (here in California our freeways suck) I hear what sounds like a scrape coming from the front; almost metallic. I do not see any thing under the wheel well or along the fender to suggest the tire is hitting, but if it is why now? Could the spindles be slightly different? Or is it coincidentally time for new shocks or springs or both up front.
1968 RS 327, TH350, 10 bolt 8.5, 3.42 Posi, Hotchkis rear leaf (1.5in drop), 4 wheel disk, 2.5" Flowmaster kit.
dmaita is offline
post #2 of 5 (permalink) Old Aug 20th, 06, 05:48 AM
Re: Strange sound after disk brake conversion
You need to find out where it's hitting.
Look for a shiny spot, it should be there somewhere.
post #3 of 5 (permalink) Old Aug 20th, 06, 07:41 AM
Vince
Backing plate touching rotor anywhere?
3forme is offline
post #4 of 5 (permalink) Old Aug 20th, 06, 07:43 AM Thread Starter
Good question! I will check, like I said I am hearing a metallic sound when this happens.
dmaita is offline
post #5 of 5 (permalink) Old Aug 20th, 06, 07:48 AM
David Pozzi
davidpozzi's Avatar
Check tire to wheelwell clearance, also rim to caliper clearance.
Discs push the wheel out aprox 1/2".
davidpozzi is offline
Rear Flex to Hard Line Mounting Bracket (disk brake conversion) dcordle Brakes, Suspension & Steering 2 Jul 25th, 06 06:29 AM
rear parking brake cable for disk conversion keith1365 Brakes, Suspension & Steering 16 Dec 5th, 05 07:54 PM
Brake conversion kits ElbowJoe Brakes, Suspension & Steering 3 May 16th, 05 05:39 PM
What disk brake conversion kit??? RSz/28 Brakes, Suspension & Steering 3 Jun 20th, 04 08:09 AM
