front disc upgrade - Team Camaro Tech
post #1 of 11 (permalink) Old Aug 20th, 06, 07:57 PM Thread Starter
Gary
front disc upgrade
I now have the famous manual 4 wheel drum brakes and would like to upgrade to power front disc setup. With all the kits out there, has anyone used them and who has a reasonable priced kit?
69 Camaro convertible 327, TH 350, fully restored, well almost.
Gary Dorion is offline
post #2 of 11 (permalink) Old Aug 20th, 06, 08:19 PM
Re: front disc upgrade
Gary -
If you want the stock type disc/drum setup, you can probably piece it together yourself cheaper than you could buy a kit. All of the parts are readily available through you local parts house, except perhaps the steel lines and backing plates.. If you have a good flaring tool and bender you can make the lines yourself, or you can buy them pre-bent from the resto houses.
Of course I also understand the convenience of a kit.
BPOS is offline
post #3 of 11 (permalink) Old Aug 20th, 06, 08:27 PM
Harley D
HarleyD67's Avatar
I haven't ordered mine yet, but I've heard nothing but great things about the product, the company, and the people.
http://www.touring-classics.com/Brake%20Kits.htm
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #4 of 11 (permalink) Old Aug 21st, 06, 09:49 AM
Watch out for the little inconveniences, like using metric theads on the proportion valve setup from the new ones that come in a kit. The result is finding the right connectors to run the lines to the master cylinder. Make sure you get the kit that has the disc spindles instead of the ones using your existing druim spindles for converting over to disc. And ALL of the "kits" are made by 1 or 2 suppliers, and their repo calipers DO NOT allow for use of stock 14" rims! So out goes the SS rims and 14x7 rallys!
Salerno is offline
post #5 of 11 (permalink) Old Aug 21st, 06, 10:11 AM
Vintage 68's Avatar
Thumbs up Re: front disc upgrade
Gary:
As Al has suggested, it is easy and very reasonable to convert your system to Disc using only GM parts.
Then finding replacement and spares will be a 'day-at-the-beach' compared to trying to service a system from a "kit" - most parts counter guys can find a GM part, but their computor doesn't have any references for 'kit' ...
A fellow team member and site moderator David Pozzi has done lots of investigation into the GM stock Disc brake system and it's installation on a 1st gen Camaro.
His site - http://www.pozziracing.com/ - has a great write-up on converting your car along with many other write-ups on upgrades and chassis modification to make it handle better also!
Many of us on the site have converted cars using this procedure, so if you have questions or run into trouble on your conversion using stock parts we can help you - not so much maybe for a "kit" ...
Hope this helps;
1968 Convertible
Some trucks
Vintage 68 is offline
post #6 of 11 (permalink) Old Aug 21st, 06, 10:58 AM
Doug
thedugan's Avatar
Send a message via Yahoo to thedugan
Gary,
What's up. I did the http://www.rightstuffdetailing.com/ kit.
Good kit, great support, got a great deal at fall carlisle.
-Doug
68 RS/SS Conv
67 Coupe
thedugan is offline
post #7 of 11 (permalink) Old Aug 21st, 06, 11:32 AM
I'll second what Doug said. Right Stuff. I talked to the the owner Dave Roberts when I placed my order and he gave me a better deal than what was advertised. Everything went together great and looks fantastic. My car also stops much better now!
John McIntire
68 SS 406 sbc, AFR 190, Comp XR288HR, RPM Air Gap, 750 Speed Demon, 5speed TKO600, 3.73
Best ET [email protected] 116.08 mph, 1.64 60'
jwmcintire is offline
post #8 of 11 (permalink) Old Aug 22nd, 06, 07:26 PM Thread Starter
Gary
Thanks, guys! Gathering info for my winter project list.
post #9 of 11 (permalink) Old Aug 23rd, 06, 12:27 AM
Craig
I bought a front & rear kit through Ricks First gen which turned out to be SSBC http://www.stainlesssteelbrakes.com/ & had nothing but trouble , they supplied the wrong instructions & there customer service is non existant , I have been trying to buy some spare parts from them for about 3 weeks but they don't seem interested.Steer clear of them!
lazyone is offline
post #10 of 11 (permalink) Old Aug 23rd, 06, 01:18 AM
madmax87's Avatar
I went with the Master Power Brake conversion and very happy with it. That included everything except brake lines. Everything fit without having to modify it. Total kit was around $1000. Went with Inline tube, just in case you need brake lines too. Fit was perfect.
madmax87 is offline
post #11 of 11 (permalink) Old Aug 26th, 06, 08:34 PM
Jerry R.
jr68's Avatar
Originally Posted by Vintage 68 View Post
Gary:
Hope this helps;
Thanks John , reading this has helped me decide what I'm going to do for my winter downtime project. David Pozzi says my drum brake spindle will work for disc brakes , this will save me bucks and I can stay all GM. Excellent link.
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
69 Manual Front Disc Brake Master Cylinder jeff5295 Brakes, Suspension & Steering 26 Nov 2nd, 06 10:33 PM
front disc brake conversion 68C Brakes, Suspension & Steering 7 Oct 23rd, 05 01:29 PM
All 1st Gen. SS's have front disc brakes? 4acamaro Brakes, Suspension & Steering 7 Jun 23rd, 05 03:45 PM
Front end kit in Canada Mark Yetman Brakes, Suspension & Steering 19 Mar 14th, 04 01:27 PM
front disc brakes improvement question Marc Brakes, Suspension & Steering 21 Dec 3rd, 03 10:47 PM
