Traction bars - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 21st, 06, 02:13 AM Thread Starter
Traction bars
Anybody here use them? I have a set that I've owned for years, and was wondering would they be worth the effort of putting them on.
When you buy an American car, you provide work for a man and his family for three months. -Jay Leno
garfield is offline
post #2 of 6 (permalink) Old Aug 21st, 06, 09:08 AM
Re: Traction bars
Only if you plan on drag racing. And then, only if you have enough power wrap up the leaf springs.
BPOS is offline
post #3 of 6 (permalink) Old Aug 21st, 06, 12:43 PM
peter
Talking Re: Traction bars
My car has single leafs, 12 bolt posi, a muncie 4 speed, and a pretty lively 350. It's safe to say that "every once in a while" I get the urge to leave some rubber. My only problem was the a$$ end would mostly hop instead of spin. I finally installed a set of Competition Engineering traction bars two weeks ago. I could not be happier with them. It's like night and day since I installed them. They totaly eliminated the wheels from hopping. The most important thing is that I can now satisfy that "urge." They are pretty easy to install. It took about me about 4 hours. I would highly recommend them if you are getting wheelhop. If you are not, and aren't racing, I would not even bother with them.
sincityrsss350 is offline
post #4 of 6 (permalink) Old Aug 21st, 06, 01:38 PM
Harley D
HarleyD67's Avatar
Re: Traction bars
If you have the power to make the rear end hop put them on. It's cheap insurance to keep from breaking/damaging something. There not just for the strip. As sincity said there good for having some safe fun on the street once in a while too. There pretty simple to install @ 1-4hrs depending on skill and help.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #5 of 6 (permalink) Old Aug 22nd, 06, 03:44 AM
Tony
Re: Traction bars
Might I add that if you install Traction Bars (exspecially C/E's "J" bolt traction bars)(not sure if Cal-Tracs cause this) install "Sub-Frame Connectors". The front snubber on the bar contacts the spring eye (as it should) but that translates to body flex which I have had/seen crack the body at the rear corner of the rear side glass/ "C" pillar area. It happened on my 68 in a matter of 2 months with just street driving.
Tony:
67 RS Clone, 388 SBC/Keisler TKO 600/12 bolt, 3.90 gear w/posi and a 250 shot of N2O for fun. See my progress at: password is camaro
idoxlr8 is offline
post #6 of 6 (permalink) Old Aug 22nd, 06, 04:46 AM
peter
Re: Traction bars
I've noticed a lot of people highly recommend subframe connectors, now that you mention them. Can anyone recommend a quality inexpensive set (like the Comp. Eng. bars). Also, how involved are they to install?
Traction bars bb489 Performance 5 May 7th, 06 03:33 PM
removing traction bars and replacing leaf springs 67SSragtop Brakes, Suspension & Steering 6 Jul 5th, 05 05:49 AM
NOS Liquid Traction Pics Run269 Restoration Corner 12 Mar 1st, 05 12:49 PM
removing traction bars sudo1a67ss350 Brakes, Suspension & Steering 4 Mar 25th, 03 06:35 AM
Questions for guys running traction bars on the street... BC Brakes, Suspension & Steering 32 May 19th, 02 05:03 PM
