Power stearing pump bracket attached to head? - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 22nd, 06, 11:23 AM Thread Starter
Duke
Send a message via AIM to dukeme
Is it necessary to have the 2 piece bracket that connects to the inside of the power steering pump? The 2 bolts are directly behind the pulley. It had A/C when the A/C compressor was removed, so was the bracket. Will the pump come loose or get out of alignment with out?
1972 Camaro Rally Sport Split Bumper 383 Stroker Motor w/Aluminum Heads, Mighty Demon 750, Posi 373, MDS, Crazy cam, TCI 3000 Stall, Power Steering Power Disc Brakes 17 Eagle Wheels,
dukeme is offline
post #2 of 4 (permalink) Old Aug 23rd, 06, 01:26 AM
madmax87's Avatar
Re: Power stearing pump bracket attached to head?
I would think without the inside bracket, your pump might not stay in place under a load. This would lead to early failure and possibly the belt coming off. You should be able to find the bracket on ebay.
madmax87 is offline
post #3 of 4 (permalink) Old Aug 23rd, 06, 01:26 PM Thread Starter
Duke
Thumbs up Re: Power stearing pump bracket attached to head?
Thanks Madmax...Got it and installed it! 550 H.P. is a load.
dukeme is offline
post #4 of 4 (permalink) Old Aug 23rd, 06, 05:16 PM
yes you need it put it on please
camaro9 is offline
no power to fule pump louis manco Engine 0 Apr 16th, 06 06:16 AM
power steering pump Pete67 Brakes, Suspension & Steering 0 Mar 19th, 06 07:48 AM
Correct power steering pump and pulley for 69 Z28 jlighthart Engine 0 Nov 15th, 04 02:52 AM
69 Power Steering Pump Adjustment bracket??? BUD Tech 2000 1 Dec 4th, 00 02:54 PM
1969 CAMARO BIG BLOCK POWER STEERING PUMP DAMCDO Tech 2000 3 Dec 31st, 99 08:48 AM
