new caliper problem - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 22nd, 06, 12:36 PM Thread Starter
new caliper problem
i guess this might be why aftermarket parts suck but wondering if anyone else has had this problem. i bought a set of calipers from classic industries for my 67 rs and they fit great but the inside pad is compressed into the disc brake. the outside pad has perfect clearance. anyone else seen this problem? any solutions? my thought was the rear pad might just be a little to thick, thought i might wear it down a little to give it more room.
CamaroSS00 is offline
post #2 of 3 (permalink) Old Aug 22nd, 06, 12:53 PM
Matt Jones
Re: new caliper problem
Not sure if I understand. So even when you apply brake pressure, the inside pad still does not touch the rotor?
Are these fixed or floating calipers?
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #3 of 3 (permalink) Old Aug 22nd, 06, 01:54 PM Thread Starter
these are fix factory disc brakes. the rear pad is smashed against the rotor with no brake pressure applied. the rotor turns but is very had to turn. which means that if i drive it i would smoke the front brakes. it looks to me like the rotor is off from where it should be. and these are brand new rotors from ricks. has anyone else bought rotors from ricks and had any problems
Covan dash cluster check engine light problem. tawodi Electrical & Wiring 0 Aug 2nd, 06 11:57 AM
caliper line to caliper, do I need an adapter? Eighttrakz Brakes, Suspension & Steering 3 Jun 23rd, 06 09:50 PM
What year Caliper ????? Chris-in-Cali Brakes, Suspension & Steering 3 Apr 9th, 06 12:50 PM
brake caliper urgent question Marc Brakes, Suspension & Steering 11 Dec 25th, 03 07:19 AM
weird starting problem matth Electrical & Wiring 2 Mar 10th, 02 05:35 PM
