New brake booster not working - Team Camaro Tech
post #1 of 10 (permalink) Old Aug 27th, 06, 10:35 AM Thread Starter
Bill
I just upgraded my brakes on my 69 camaro from manual drum/drum to power disk/drum. My booster is not working at all. It is the same with the vaccuum hose on or off. The brakes work fine, have been bled and are not spungy. Here is what I have done so far. Any help would be greatly appreciated.
I bought the plastic boot from NPG and used that. The rubber boot from my old MC would not fit where the lever goes into the booster so I just used the plastic one. (I'm thinking that may be my prob). I also replaced all brake lines but used the original man brake metoring valve. The vaccuum hose goes to my int manifold and is getting great vaccuum. The cam is mild so vaccuum shouldn't be an issue.
Thanksk,
Bill
bgreen63366 is offline
post #2 of 10 (permalink) Old Aug 27th, 06, 04:31 PM
Rick
Camaro67_rcl's Avatar
Send a message via Yahoo to Camaro67_rcl
Re: New brake booster not working
Did you move the connection on the brake pedal arm to the other hole for power brakes?
Camaro67_rcl is offline
post #3 of 10 (permalink) Old Aug 27th, 06, 11:01 PM Thread Starter
Bill
I did. My brakes work fine but they are not power assisted. I am wandering if there is a vaccuum leak or did I install it wrong
post #4 of 10 (permalink) Old Aug 28th, 06, 12:29 AM
is the check valve in the booster installed backwards?
that 90 degree plastic fitting for the vacuum line is a check valve so it must be installed in the correct dirrection
400bird is offline
post #5 of 10 (permalink) Old Aug 28th, 06, 06:23 AM Thread Starter
Bill
I checked, it's in right.
post #6 of 10 (permalink) Old Aug 28th, 06, 07:32 PM
well then if it has vacuum and the check valve is in the correct direction sounds like the only thing left is for the booster to be bad
if you hold the brakes down then start the car does the pedal drop closer to the floor at all?
400bird is offline
post #7 of 10 (permalink) Old Aug 28th, 06, 09:00 PM
On the front side of the booster, where it joins with the master cylinder, there should be a black rubber washer like thing that fits snugly into the opening of the booster. Without it, you booster will have a huge vacuum leak and probably won't boost. You can almost sorta kinda see it in this picture if you use your imagination.
BPOS is offline
post #8 of 10 (permalink) Old Aug 29th, 06, 12:36 PM Thread Starter
Bill
400Bird No pedal drop at all.
Al, I will check that. Could there be a vaccuum leak in the back where the rod goes in? The only boot I found for it was a plastic one that seals to the firewall. Thanks again for all your input guys.
Bill
post #9 of 10 (permalink) Old Aug 30th, 06, 11:33 AM
Bill
if the pedal doesnt drop when you start the car then you really are getting no assist, so i would check what bpos said check for the seal in the end, but it looks to me like its time for a new one otherwise
400bird is offline
post #10 of 10 (permalink) Old Aug 31st, 06, 03:44 PM Thread Starter
Bill
The problem is that it is brand new lol. guess i'll remove it and exchange it.
Thanks again guys
Bill
Vacuum leak no, its a brake booster 400bird Brakes, Suspension & Steering 4 Feb 27th, 06 09:13 PM
9204 brake booster 69Z28 Camaro Tech 15 Aug 25th, 05 06:11 AM
power brake booster 69ss350camaro Brakes, Suspension & Steering 2 Dec 7th, 04 03:05 PM
power brake booster 69ss350camaro Performance 1 Dec 6th, 04 10:44 AM
68 SS brake booster help davezila Brakes, Suspension & Steering 2 Oct 22nd, 04 01:27 AM
