power steering assembly (Spring fell out) - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 27th, 06, 06:46 PM Thread Starter
Johnny
Question power steering assembly (Spring fell out)
I might have a problem. I took the pump off to paint it and when I took the pressure line off,a spring and nipple thing fell out of the hole. I am not sure of what order it goes back in. The reason this happened is because I did not realize that the pressure line is attatched to a coupling that is part of the pump.
67Camaro 396BB 750Holley, edlebrock performer,280isky,3.42 posi, turbo 350,stage 2 shift kit, 2800 stall, MSDready to run distributor, headers, 2.5"exhaust, Hotchkis(1.5"/2"drop).(orig.Deep water blue/light blue dlx inter, v8 column shift/bench seat)
johnny67 is offline
post #2 of 5 (permalink) Old Aug 27th, 06, 07:14 PM
Re: power steering assembly (Spring fell out)
The spring goes in first all the way to the bottom , and then the plunger with nut end in first and then the fitting with the o/ring and then the pressure line .
Mark .
pictures can be viewed at
Mark .L.W. is offline
post #3 of 5 (permalink) Old Aug 27th, 06, 09:16 PM Thread Starter
Johnny
Well that will explain it fellow B.C. boy lol. That is one beautiful car you have, I would say all the magazines will come knockin.
I put it with the plunger first then the spring. I guess that would explain why I don't have any power steering lol.
johnny67 is offline
post #4 of 5 (permalink) Old Aug 28th, 06, 09:43 PM Thread Starter
Johnny
Thanks again Mark, I installed it right and it works like a charm.
johnny67 is offline
post #5 of 5 (permalink) Old Aug 29th, 06, 11:05 AM
No problem at all , most poeple I reply to are in the States , there is some of us goodguys hear in Canada .
Mark .
Replacement Part Numbers for Steering/Suspension - LONG HwyStarJoe Brakes, Suspension & Steering 14 Sep 16th, 12 10:50 AM
Power Steering And Header Clearence JAKER110 Brakes, Suspension & Steering 8 Jul 20th, 05 04:00 PM
Twitchy 3rd gen power steering box Midnight68 Brakes, Suspension & Steering 7 May 26th, 05 05:31 PM
trouble adding power steering to my 67 RS DPeter2101 Brakes, Suspension & Steering 6 Apr 6th, 04 08:06 PM
Power steering problems!!! dustys Troubleshooting 5 Mar 10th, 00 11:26 AM
