How to dispose of old monoleaf rear springs? - Team Camaro Tech
post #1 of 13 (permalink) Old Aug 28th, 06, 11:35 PM Thread Starter
I replaced the original monoleaf rear springs on my 68 Camaro with multileaf springs. Now, what to do with the old springs? Are they dangerous for someone else to use? Are they sellable? Are they recycleable for the spring steel in them? Any ideas, other than bury them in the back yard?
ggkeller is offline
post #2 of 13 (permalink) Old Aug 29th, 06, 01:32 AM
Re: How to dispose of old monoleaf rear springs?
Sell them. No they are not dangerous, and sometimes preferred over multi leaf.
Metal recyclers if you have no buyers.
BlackoutSteve is offline
post #3 of 13 (permalink) Old Aug 29th, 06, 09:17 AM
Talking Re: How to dispose of old monoleaf rear springs?
I sold my pair for 60$ on ebay. 6 years ago.. I was plesantly surprised.
Long Gone: 1984 Z28, 1989 RS
Current : 1967 Coupe w/350, 2010 2SS
My Photobucket >>
dragon0123 is offline
post #4 of 13 (permalink) Old Aug 30th, 06, 07:48 AM
On another note, I also have a 68 w/ mono springs. How difficult was the change to multi leaf?
thanks,
Had a 1968 Camaro Convertible w/ tilt wheel, power brakes, power steering, console gauges and tic toc tach. Sold it! and on the prowl for the next one.................
rbiss1359 is offline
post #5 of 13 (permalink) Old Aug 30th, 06, 08:12 AM
Actully pretty easy.. except for maybe the rust.. most all of the bolts holding mine in were giving it the death grip.. the 3 front bolts on each spring perch needed to be ground off. Other bolts needed to be cut in half.. youll need either new perches welded on the axel or cant remember if they make adapters for this or not.... ?? that would be your biggest mod if needed..
New shackels, mostly new bolts.. shock sizes will be different unless you get the shock adapters that lengthens the shock length..
Did mine a few years ago so some of it is schetchy in my mind..
My Photobucket >>
post #6 of 13 (permalink) Old Aug 30th, 06, 08:30 AM Thread Starter
I bought the 3-leaf springs from JC Whitney. They seem to sit in the mono-leaf perches well enough to hold them in place. I didn't want to mess with changing the perches. I don't think they change things enough to worry about shock absorber changes. I also went with the 3-leafs because from what I read on this site, the 4 and 5 leaf ones really stiffen up the ride and I wanted to minimize that. So from what others have said, the old springs don't suffer from metal fatigue failure risk, and they are still safe to use? I worried that with a mono-leaf if it breaks you would have a serious problem of rear axle separation from the car.
ggkeller is offline
post #7 of 13 (permalink) Old Aug 30th, 06, 09:39 AM
Fred
77thor's Avatar
I'm just amazed that someone would buy (35+ yr) old springs.
77thor is offline
post #8 of 13 (permalink) Old Aug 30th, 06, 09:41 AM
Ron
They make great Knife blade steel. I used a section of spring from my 68 to make a custom knife which I have been known to do from time to time and was happy with the results. If I get the time I may make a few more.
Now restoring 68 Z22
Too Many Corvettes & not enough Camaros!
My skills in the shop are far better than my typing skills!
Corvettemaster is offline
post #9 of 13 (permalink) Old Aug 30th, 06, 10:03 AM
You may want to see if a local body shop will let you throw them on the scrap steel pile, if you want to just get rid of them.
TJS69 is offline
post #10 of 13 (permalink) Old Aug 30th, 06, 10:46 AM
Its too bad you don't live closer, I"d ask you to send them to me, I'd even pay for freight.
post #11 of 13 (permalink) Old Aug 30th, 06, 11:52 AM
Im sure a recycling center would take them.. you may even get a few dollars from them that way..
My Photobucket >>
post #12 of 13 (permalink) Old Aug 30th, 06, 12:20 PM
Kevin
KevinW's Avatar
If you were closer, I would take them off your hands
Kevin
KevinW is offline
post #13 of 13 (permalink) Old Aug 30th, 06, 12:21 PM
tyrfryrtom's Avatar
You would be suprised at the number of people buying parts to complete a car. Missing or just wanting "Genuine" parts to recondition.
tyrfryrtom is offline
What rear springs match Eibach height? topdown69 Brakes, Suspension & Steering 0 Aug 10th, 05 06:12 PM
New rear multi-leaf springs 1967 convertible elcamino72 Brakes, Suspension & Steering 4 Jan 14th, 05 08:29 AM
New rear springs, what is stock height???? Erik Beckett Brakes, Suspension & Steering 2 Mar 30th, 04 12:45 PM
Hotchkis Rear Springs Anyone using them kwissman Brakes, Suspension & Steering 6 Feb 23rd, 01 02:21 PM
Lowered Rear Springs Al N Brakes, Suspension & Steering 17 Apr 5th, 00 06:39 PM
