Hi, I have 69 camaro that seems to be leaning to the right side, I have replaced the shocks and all the springs, My car is definetly riding better than before however the lean is still there, any thoughts on what could be causing the lean, could the subframe bushings cause this???
my 67 firebird does the same thing. I replaced the subframe bushings and it cut the lean in half. About 1/2 an inch difference between the tire and front fender side-to-side. Never figured it out. However, it does watch FOX news when I am away...
Had the same problem after replacing my front springs and discovered that one of the springs was not seated all the way in the A-arm. Just had to twist it a few degrees. Compare both sides and see if they differ.
Related Threads
Team Camaro Tech
2.4M posts
83K members
Since 1998
