Confirm my Back Spacing Please - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 8th, 07, 01:05 PM Thread Starter
Okay Guys I ran a search and it appears that most of you are running 245 or 255 60.15 on 15x7 or 15x8 rims with a 4.5 b/s. So before I go out and change what I currently am running. I need to hear that Im going down the correct road. I currently am running 235 70 15s on 5.5 b/s Weld Pro Star 15x8 rims on the rear of my 69 and even with a 5/16 spacer. ( I know I hate them too https://www.camaros.net/forums/images/smilies/mad.gifit was on the car when I bought it) I still rub on the drivers side going in and out of driveways. I think my whole problem is the b/s on the rim. So I am going to order a set from Weld with 4.5 b/s and then go with a set of 255 60.15 BFGs Does anyone out there think I going to run into trouble. I know its a wider tire that Im running now but by moving from a 70s to 60s series tire and changing the b/s from 5.5 to 4.5 I think I should be okay based on the posts that Ive read. Thanks Guys
Edneck is offline
post #2 of 5 (permalink) Old Feb 8th, 07, 02:28 PM
Re: Confirm my Back Spacing Please
a 255 on an 8" with 4.5" bs will be fine
And since you're new here, Welcome to Team Camaro!
post #3 of 5 (permalink) Old Feb 8th, 07, 05:51 PM Thread Starter
Thanks Jim..... sometimes you just need to hear from someone else what you think you know
Edneck is offline
post #4 of 5 (permalink) Old Feb 9th, 07, 02:13 PM
On a 15 x 8 wheel with 4.5" bs you should be able to go as big as a 275/60 without issues (on a stock height car). So a 255/60 should have plenty of room.
68 Camaro~LSx ~all motor
post #5 of 5 (permalink) Old Feb 9th, 07, 05:46 PM
Dan
Yes, What Jim said x2
__________________________________________
Dan
69 coupe, 350 crate motor/Th350c trans with 2.75 low first gear--2500 lock-up converter
Not a show car, just a part time Driver!!!
pappy's69 is offline
Chat's back up!!!!! 10:00 pm, cst, 9-16-06, chat's back up!!!! JimM Bench Racing 11 Sep 17th, 06 06:58 AM
Is it OK to have some slop in the hood hinge rivet attachements? ggkeller Body Shop 9 Oct 27th, 05 01:40 PM
Door adjustment Unreal Body Shop 7 Mar 2nd, 03 01:54 PM
Rear of hood does not line up SSuperman Body Shop 9 Apr 1st, 02 05:00 PM
How big / back spacing 67rag Wheels & Tires 1 Mar 5th, 99 08:21 PM
