5" Back Spacing on 15x7 Rallys? - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 9th, 07, 06:28 AM Thread Starter
Clint
Will 15x7 Rallys with 5" back spacing work on my 69 coupe? The rims are from a mid seventies corvette? From what I read on here it sounds like everyone is using 4" bs on the 15x7 rallys. Thanks in advance for any help.
Clint
cwb90 is offline
post #2 of 3 (permalink) Old Feb 9th, 07, 09:54 AM
DjD
DjD's Avatar
Re: 5" Back Spacing on 15x7 Rallys?
Well, it will leave you with just 2" of rim and tire on the outside by the fender lip. That is a full extra inch away from the fender lip. I don't think that would look very good.
I bet the mid 70's vette wheels are 15x8 though and other than being real close and possibly rubbing on the inner fender a bit would work. I had 15x8 5" bs on the back of my '69 with 255/60-15's and in corners they rubbed a bit...
...Dennis
DjD is offline
post #3 of 3 (permalink) Old Feb 9th, 07, 01:17 PM
Dan
Clint,
I have 15x7 with 4 1/2 bs on all 4 corners of my 69.I have 235/60 on the front and 275/60 on the rear.This combo fits with no rubbing.My car set at stock level and not lowered.It's in my opinion that is the most back spacing you can use with these size tires.The front tires will clean off the dirt on the frame rail if you corner hard with the steering locked left or right.
_ See picture in profile
_____________________________________________
Hope this helps
Dan
69 coupe, 350 crate motor/Th350c trans with 2.75 low first gear--2500 lock-up converter
Not a show car, just a part time Driver!!!
pappy's69 is offline
Door adjustment jsouthco68camaro Body Shop 9 Mar 7th, 05 05:46 AM
Door Hinge & Remount Question Dwight's Z/28 Body Shop 3 Oct 9th, 03 02:26 PM
1968 door alignment Steve W Body Shop 5 Sep 9th, 03 04:15 PM
Trunk Lid Fit Problem RPOL72 Body Shop 8 Aug 27th, 03 01:45 AM
Hood adjustments!! Handy69Z Body Shop 2 Mar 13th, 03 04:14 AM
