Will these fit a 69?? - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 17th, 07, 07:50 PM Thread Starter
Nick
Rarerat's Avatar
http://cgi.ebay.com/ebaymotors/17-11...6508QQtcZphoto
Just wondring what the chances of this rim & tire combo fitting a stock suspention 69?
Thanks in advance,
Nick
Rarerat is offline
post #2 of 3 (permalink) Old Feb 18th, 07, 05:04 AM
Re: Will these fit a 69??
Direct answer - NO. Now the rear 17x9.5 with the 275/40 tire can be made to fit in the rear with the correct size adapter (bolts to the hub and the wheel bolts to the studs on the adapter which can be ordered in the thickness you need. In the front you can get a 245/45-17 on a 8.5 wide wheel (those wheels come in that size) with the correct adapter to work. The 315s will not fit at all unless you mini tub. Do a search on adapters and spacers you will see lots of info on this. Also keep in mind "good" adapters that are hub centric are not cheap - $200.00 or better. You can find them on Ebay also. Hope this helps.
Jack
JV69z/28rs is offline
post #3 of 3 (permalink) Old Feb 18th, 07, 07:05 AM Thread Starter
Nick
Rarerat's Avatar
JV69z/28rs,
Thanks. I didnt have a clue what would fit and what wouldnt. I have a bent rally wheelon my Blue 69 and I have bought 3 used wheels locally and they have all been bent. I have been pretty disgusted and Thought I might try something else. I saw those on ebay and thought they were a great deal.
Thanks Again,
Nick
Rarerat is offline
'69 SS396 - 2000 T56 Install SKIPS69 Transmission & Driveline 8 May 6th, 07 01:18 PM
69 Z28 Exhaust System Questions??? W.A.C Camaro Tech 14 Mar 16th, 07 09:51 AM
67 Chevell 12 Bolt Rear End Fit ? JAKER110 Transmission & Driveline 15 Dec 13th, 06 05:39 AM
What Size Ralley Wheels fit best on a 69 Camaro? irethedo Wheels & Tires 10 Mar 1st, 06 09:23 PM
Will 255s fit on the rear of a 69? Joe 69 Wheels & Tires 6 Nov 29th, 05 06:28 PM
