Draglites and Drag Radials - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 17th, 07, 09:33 PM Thread Starter
How would a 255/60/15 Mickey Thompson Drag Radial look on a 67 Camaro, with 15x8 4.5''bs draglites?
Car has a 10 bolt 8.5'' from a 71 Camaro, so it's what an inch wider total?
Thanks!
'67 Camaro in the works...
Newbomb is offline
post #2 of 7 (permalink) Old Feb 18th, 07, 05:06 AM
Harry
dawg's Avatar
Re: Draglites and Drag Radials
its what i got on my camaro
heres a pic:
ive since lowered the rear which makes it look even better.
OPPPS sorry wrong year camaro lol.
heres one with more of a side view:
434 stroker
US Navy retired
dawg is offline
post #3 of 7 (permalink) Old Feb 18th, 07, 12:54 PM
Since the rear is wider than stock, you'll need more backspace. If rear is 1" wider overall then add 1/2" to backspace per side. 4.5" on a stock rear works well, so you "should" need 5" backspacing. Measure it.
68 Camaro~LSx ~all motor
post #4 of 7 (permalink) Old Feb 18th, 07, 01:32 PM Thread Starter
The 4.5'' fit fine, I don't think they make a Draglite or Pro star in 8'' with 5''bs, I think its 5.5'' bs....
I'm curios to see as how the 255 would look compared to me gambling with the 275-60....I have 28x10.5 ET Drags on now But they are a bit on the big side...
I think I should lower my rear end an inch or so....
Newbomb is offline
post #5 of 7 (permalink) Old Feb 18th, 07, 03:36 PM
Now if you were to lower that as it is you would see you need more backspace due to the tire hitting the wheelwell lip. If you lower the car and install a shorter/narrower tire it will have the same gap and gain nothing but a lower car.
This is a 285/60/15 SH (sh = short) McCreary's on an 15x8 with 4.5" bs. Yes they rub but only slightly (off camber bumps,hard corners)
http://i10.photobucket.com/albums/a1.../28560s005.jpg
http://i10.photobucket.com/albums/a1...59460974-S.jpg
post #6 of 7 (permalink) Old Feb 18th, 07, 03:40 PM
6D9
Ron
Doug is right...4.5" probably wont work with the wider rear end. I am running 275/50/15's BFG Dr's on Weld's 15x8's with 4.5" bs. It barley fits and I still needed to trim the fender lips. Check with center line. They have there Convo Pro's with 5" bs. The 235/60/15's should fit with 4.5" bs and are still 26.1" tall. They are a nice fit on 8" wide wheels.
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #7 of 7 (permalink) Old Feb 18th, 07, 05:12 PM Thread Starter
I would go with a 275 50...but it's wider than the 60....those 28x10.50's fit without rubbing at all (before chassis problem)
I don't know if they make a 8'' 5.5''bs rim from Weld....that might be too close to the inside.....
I'll go size it up tomorow...
Newbomb is offline
15X10 Draglites?? NW S/D Wheels & Tires 5 Jul 30th, 04 12:39 AM
