Rear lower shock mount with 17" wheels ?? - Team Camaro Tech
post #1 of 11 (permalink) Old Feb 18th, 07, 07:22 PM Thread Starter
Marc
mnm99's Avatar
If your looking on the inside part of the rim my 14" wheels are about 1/2 inch away from the lower shock mount bolt with 4 1/4 backspacing. If I went with 17's would the shock mount be on the inner edge of the rim? I'm going with 17x9 with 5" backspace. Any pictures? Just wanted to make sure they wouldn't hit.
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
mnm99 is offline
post #2 of 11 (permalink) Old Feb 18th, 07, 09:51 PM
Re: Rear lower shock mount with 17" wheels ??
i have wheel vintiques steel rallys, 17x9 with 5" backspace and they fit fine. with only a 9" wheel width, i would have perferred a 5 1/4" or 5 1/2" backspace, as i had to roll the fender lip to prevent contact on the outside. you should have no problems with the shocks inside.
guccieng is offline
post #3 of 11 (permalink) Old Feb 19th, 07, 04:40 AM Thread Starter
Marc
mnm99's Avatar
What size tire do you have?
When I did my measurements from the mounting surface to the inner well I got 6 1/4" , and from the mounting surface to the beginning edge of the fender lip(inner edge) I got 5". So I figured with a 9" rim and 5 inches of backspacing that would give me 5 inches in (1 1/4 to spare ) and 4 inches out (1 inch to spare). Was this close to your measurements?
mnm99 is offline
post #4 of 11 (permalink) Old Feb 19th, 07, 04:50 AM
With 17's, the lower shock mount will tuck nicely completely inside the rim.
post #5 of 11 (permalink) Old Feb 19th, 07, 05:56 AM Thread Starter
Marc
mnm99's Avatar
Thanks Jim. I have another question.. What size rim do I have? I measured my 14 inch rims and I'm not sure if its correct. It's a sad picture. Can you make it out?
Current tire 235/60/14 with 2 inch drop and it doesn't rub.
If this is correct? If so wouldn't I be able to use a 17x7 with 3 3/4 backspace and a 225/45 tire? The reason I'm asking is Newstalgia Wheel said it wouldn't work. Whats your take? I could only get a 17x7 in a 3 3/4 backspace or a 8 in a 4 1/2 backspace.
mnm99 is offline
post #6 of 11 (permalink) Old Feb 19th, 07, 06:22 AM
I "think" your drawing is an 8" rim with 4 1/2" of backspace, just with some measuring wierdness.
An 8" rim with 4 1/2" backspace is "normal" on a 68, it's what I run and everything clears fine.
a 225/45 tires is a tiny lil thing tho, relatively narrow and very short. I run a 255/45 in back and they clear fine. The 17 x 7 - 3 3/4"bs should fit too.
post #7 of 11 (permalink) Old Feb 19th, 07, 06:59 AM Thread Starter
Marc
mnm99's Avatar
I have the 235 on the front now. If I do have a 8" rim the 7" would bulge the 235 more. Using the calculator You posted I came up with.
235/60/14--(9.25" wide) and (25.10" tall) recommended wheel (6-8.5)
225/45/17--(8.85" wide) and (24.97" tall) recommended wheel (7-8.5)
I didn't think it was that far off.
I was going with 17x9 with 5" backspace and a 255/45/17 in the rear.
(10.03" wide) and (26.03" tall) recommended wheel (8-9.5)
mnm99 is offline
post #8 of 11 (permalink) Old Feb 19th, 07, 08:05 AM
a 255-45-17 is perectly happy on an 8" rim, think it would look funny on a 9.
And for some reason I thought we were taling about the front before.... oops.
On the front, I run a 225/50/16 on a 7" 3 7/8" bs wheel, no problem. Think I'd rather have a 4" bs than 3 3/4" tho.
post #9 of 11 (permalink) Old Feb 19th, 07, 10:50 PM
my measurements are the same. i have the 'standard' 275/40r17 with no problems.
guccieng is offline
post #10 of 11 (permalink) Old Feb 20th, 07, 04:54 AM Thread Starter
Marc
mnm99's Avatar
What size rim do you have and backspacing? Also what do you have on the front?
I really wanted the vintage V40 for the front but the 17x7 only comes in a 3 3/4 backspace.
The rear I was looking at 17x9 with 5 inch backspace. Jim thought the 255 would look lost. I would love to put a 275 on there, but I'm afraid of it rubbing. remember I have a 2 inch drop on the front and 1 1/2 in the rear.
Can you post some pics? I have a 68 also.
mnm99 is offline
post #11 of 11 (permalink) Old Feb 20th, 07, 07:34 AM
When I went to the strip last October, I had occasion to borrow some ET Streets. They were 275 on 15, on a 7" rim. Not sure unfortunately what the backspace was on the rims. They were original 79 second gen rims, and I'm guessing were zero offset (3 1/2" backspace.)
They were into the inside of the fenderwell slightly on one side only.
Later measuring showed the rear was offset in the car a 1/4", giving 1/2" more inside clearance on the left than on the right. If the rear was centered, they woulda cleared.
67 shock mount plates JOHNRSWEAT Brakes, Suspension & Steering 7 Jan 6th, 07 03:30 PM
Rear Sway Bar won't Mount Correctly Michael 1969 X44 Brakes, Suspension & Steering 6 Sep 30th, 06 01:04 PM
Cowl Hood Not lining Up Ken Miele Body Shop 15 Apr 11th, 06 01:25 PM
Rear shock mounts jumpstart Brakes, Suspension & Steering 5 Feb 13th, 06 09:25 AM
Rear Shock Plate 69z22 Brakes, Suspension & Steering 0 Sep 3rd, 05 06:01 PM
