Your opinion on tire size? - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 19th, 07, 07:44 PM Thread Starter
Ted
I ordered my rims for my 69 today, TTII's - fronts 17x8, 4.75bs and 17x9.5, 5.5bs for the rears. By the many posts I have read for the rears most are going with 275/40/17. But for the front I have seen both 235 and 245/45. Just want to know your opinion on which way to go and why. Thanks. Long live the first generation!
tgifford5 is offline
post #2 of 4 (permalink) Old Feb 20th, 07, 06:27 AM
Dean
Re: Your opinion on tire size?
I have 245/45/17 with the same bs and rim size as you on my '69. I have zero rubbing anywhere with disc brakes.
FWIW I have 285/40/17 5.5 bs out back only because they were cheaper than the 275 at the time. I lowered the rear as well and added disc brakes, so I did have to roll the lips a bit.
Dean
'69 355-3.73 Moser-Truetrac-TKO-600-Hotchkis-DSE-QA1 coilovers-Baer brakes-17"Budnik's-Speedtech control arms
SICKT9 is offline
post #3 of 4 (permalink) Old Feb 20th, 07, 08:18 AM Thread Starter
Ted
Also wanted to add that my front has disc brakes and Eibach 1" lowering springs. And the rear has drum brakes and 3 leaf mono replacement springs. If that changes any suggestions.
post #4 of 4 (permalink) Old Feb 22nd, 07, 09:50 PM
6D9
Ron
I have 245/40/18's (4.75bs) on the front of my 69 and they rub the outer fender. My car is lowered 2" with Hotchis drop springs. I would go with the 235's. They also look better to me as well because they really straighten up the side walls on the 8" wheels.
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
another whats the largest tire size ??? Jeff22 Wheels & Tires 11 Sep 10th, 06 06:33 PM
Tire size brcamaro Wheels & Tires 3 Jul 27th, 06 05:43 PM
Question about tire size and gearing tommyg Performance 6 Jun 15th, 05 12:57 PM
Rear tire size limitations with stock fender well size??? BuddyP Wheels & Tires 4 Apr 1st, 05 02:03 PM
finally new wheels and tires michaelm5 Wheels & Tires 14 Jul 12th, 02 01:09 PM
