Passenger front wheel hit ssubframe--is this a camber issue? - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 27th, 07, 10:43 AM Thread Starter
Brent
Brentmc's Avatar
My passenger side front tire hits my subframe at full left lock (the driver's side is fine). The tires are 235/60/15's on 15x7 FW code rally wheels.
Is this just a matter of changing the camber on the passenger side so that it doesn't turn so far?
Here is the driver's side at full lock--it has plenty of room:
1968 RS/SS Lemans Blue
Brentmc is offline
post #2 of 7 (permalink) Old Feb 27th, 07, 12:57 PM
Vince
Re: Passenger front wheel hit ssubframe--is this a camber issue?
Have you had it aligned lately? Adjustment in the TR ends might help...................I'd pay a few sheckles and take it to an alignment shop.
3forme is offline
post #3 of 7 (permalink) Old Feb 27th, 07, 01:28 PM
Is your steering wheel straight when you are going down the road?
You could actually fix this at home with a tape measure. Scribe a line circumferentially around each tire and check your toe-in with a tape measure at a point about 4" off the floor by comparing the measurements between the lines from the fore and aft sides of the tire. Loosen the passenger side tie rod sleeve and shorten the tie rod until the tire won't touch the frame. Tighten the tie rod sleeve then lengthen the other side until the toe-in is back at the original setting. Make sure you roll the car fore and aft a few feet to get any twist out of the tire before you settle on the initial and final measurement.
onovakind67 is offline
post #4 of 7 (permalink) Old Feb 28th, 07, 12:41 AM
that would work as long as he is not hitting the steering stops on the lower control arm, but with 235's i think he would be
so before trying this method check to see if you are hitting the stops on the lower control arm at full lock
400bird is offline
post #5 of 7 (permalink) Old Feb 28th, 07, 05:03 AM
That's what the steering stops are for, to stop the wheels/tires from hitting something in the fenderwell. The pictures show the tire clearly hitting the frame, so the steering stop isn't being utilized. You could possibly modify the steering stop so it is engaged before the wheel hits the frame.
post #6 of 7 (permalink) Old Mar 1st, 07, 09:46 PM
David Pozzi
davidpozzi's Avatar
Yes, check your steering stops and see if they touch at full lock. One of them might be bent or your steering may not be centered properly.
davidpozzi is offline
post #7 of 7 (permalink) Old Mar 2nd, 07, 12:38 AM
sorry i cant see the pictures, stupid web block thing here at school
but yes you are right about his problem
400bird is offline
Replacement Part Numbers for Steering/Suspension - LONG HwyStarJoe Brakes, Suspension & Steering 14 Sep 16th, 12 10:50 AM
Cowl Hood Not lining Up Ken Miele Body Shop 15 Apr 11th, 06 01:25 PM
Replacing lower front quarter (behind wheel) Shawn Body Shop 4 Jun 9th, 02 09:52 AM
Front Wheel Bearing Grinds Gregg73 Brakes, Suspension & Steering 6 Dec 20th, 01 07:13 PM
FRONT LEFT WHEEL OUT OF PLACE CESARE 327 RSA Troubleshooting 4 Jul 5th, 00 02:15 PM
