68 Camaro Wheel/Tire Combo - Team Camaro Tech
post #1 of 13 (permalink) Old Mar 2nd, 07, 01:33 PM Thread Starter
.gearhead.'s Avatar
I recently purchased a 68 Camaro with Weld wheels. The wheel wells are stock, the fender lips are not rolled, and it has CalTrac springs and bars. I'd like to get a second set of wheels. I want the Torq Thrust II wheels. I'd like to put 18x10 on the rear, and 17x9 on the front. Does anyone KNOW FOR SURE if this combo will work? Or anyone know for certain what the biggest rear combo is that will work on this car? Thanks in advance.
.gearhead. is offline
post #2 of 13 (permalink) Old Mar 2nd, 07, 02:32 PM
Marc
mnm99's Avatar
Re: 68 Camaro Wheel/Tire Combo
Search button........
From all the measuring I did you only have 11" on the inside well to play with, MAX. So a 10" rim is really 11" then you have tire bulge, say 1/4. So no is your awnser. A 275 tire measures 11'" and if you put it on a 10" rim it would look funny.
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
mnm99 is offline
post #3 of 13 (permalink) Old Mar 2nd, 07, 02:40 PM Thread Starter
.gearhead.'s Avatar
Thanks. I'm searching the forum also...
It currently has Weld 15x8 wheels with 28x12.5 ET Street tires...
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
post #4 of 13 (permalink) Old Mar 2nd, 07, 02:50 PM
Marc
mnm99's Avatar
Your rear must be up right? Are you past the lip on the outer fender?
mnm99 is offline
post #5 of 13 (permalink) Old Mar 2nd, 07, 02:52 PM Thread Starter
.gearhead.'s Avatar
It sits on Caltrac springs and bars. I think it's really close to stock height. Does not appear to be past the lip. Here are 2 pics.
Now: Boost...
post #6 of 13 (permalink) Old Mar 2nd, 07, 03:28 PM
Marc
mnm99's Avatar
How much clearance do you have between the tire and fender lip? Does it ever rub over bumps? I have the Hotchkis kit , so those tires would never work on my car.
mnm99 is offline
post #7 of 13 (permalink) Old Mar 2nd, 07, 03:44 PM
12.5 being the width?
How do you fit that on an 8 inch rim?
I have 15X8's too with a 275 60R15 on there. I've been trying to figure out how I can get a 10 inch wide rim on mine.
mkpatrick is offline
post #8 of 13 (permalink) Old Mar 2nd, 07, 04:11 PM
28/12.5 and stock wheelwells ??? I don't see it. I'm running 285's which come out to 11.25" and they're tight. Hard corners or off camber bumps they rub the inner well. 285/60/15 SH (SH=short) McCrearys
68 Camaro~LSx ~all motor
post #9 of 13 (permalink) Old Mar 2nd, 07, 04:34 PM
.gearhead R U sure that Camaro is not mini tubed?
Bolt is offline
post #10 of 13 (permalink) Old Mar 2nd, 07, 06:46 PM Thread Starter
.gearhead.'s Avatar
Definitely no mini-tubs. Stock setup. I think the 15x8 wheels pull the sidewalls and narrow it a bit. Just a hunch.
Now: Boost...
post #11 of 13 (permalink) Old Mar 2nd, 07, 07:18 PM
Tristan
Send a message via AIM to Mav68erick
hmm draglite rims pinned hood? theres something about the rear of that car? shocks relocated? I cant see how that tire fits like that..
I got the My 275s like 28 high on my uncles camaro for reference and it sticks out of the fender like 2-3 inches and only has about an inch before the 15" rim hits the shock perch so it would still stick outta the fender. plus the tires on that car look way bigger?
68 Camaro
I Hate Spotwelds
Mav68erick is offline
post #12 of 13 (permalink) Old Mar 2nd, 07, 07:34 PM Thread Starter
.gearhead.'s Avatar
I'll check the shock mounting points. The car is in a garage 2 hours away until next weekend. I'm not sure if the shock mounts are moved a bit when the Caltrack leaf setup is installed. I'm a coil spring guy. I have to brush up on my Camaros now. Maybe someone else would know that?
Now: Boost...
post #13 of 13 (permalink) Old Mar 2nd, 07, 08:21 PM
Brandon
I also have a 26x12.50x15 m/t sportsman on an 8.5" wheel with factory wheelwells. I don't know the backspacing since the wheels were purchaced 15 years ago.
Mine has Lakewood traction bars that the shocks mount to. I don't know how they fit either, but they do. I want to upgrade to a 17 or 18inch wheel to get into the 21st century in the worst way!!! when I unbolt them I can post the offset
brandonc707 is offline
Wheel and tire combos for 68 Camaro SSCam427 Wheels & Tires 5 Mar 14th, 06 03:58 PM
DIY Network 1968 Camaro Restoration Show Brentmc Bench Racing 2 Mar 14th, 06 09:41 AM
68 camaro new engine bmattie Bench Racing 5 Mar 9th, 06 04:05 PM
68 camaro wheel/tire combo keith1365 Wheels & Tires 10 Aug 25th, 05 12:19 PM
