16 In Rally Wheels? - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 10th, 07, 08:26 AM Thread Starter
16 In Rally Wheels?
I just put on a new set of 4 wheel disc brakes on my 68 and the 15 inch rims dont fit even though when i bought them they said they would, i was wondering if they made a 16 inch rally wheel and where would i find them.
rpm4983 is offline
post #2 of 4 (permalink) Old Mar 10th, 07, 08:36 AM
Mike, 69's rule
zuma's Avatar
Re: 16 In Rally Wheels?
First of all, welcome to Team Camaro, Try this place, they should have what you need. You might find a place closer to you but, this is a nice place to start...
http://www.stocktonwheel.com/rally_wheels.htm
(STAY THIRSTY, MY FRIENDS).
1969 Camaro
1990 IROCZ28 convertible (SOLD)
2004 Silverado Z71 4x4
2008 Pontiac G8 GT
GGSMU member
zuma is offline
post #3 of 4 (permalink) Old Mar 10th, 07, 08:51 AM
Andrew
Andrew69's Avatar
Be careful. I tried to find a 16" wheel to fit over my brakes and found that the 16" wheel has the same center section as the 15" but they put a larger diameter rim around it. You actually won't gain any appreciable clearance. If you do find one I would like to know about it.
I believe the exception might be the billet aluminum wheels distributed by http://www.wheelvintiques.com/
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #4 of 4 (permalink) Old Mar 11th, 07, 05:37 PM
Bob
Wheel Vintiques sells many sizes of ralleye wheels. They are Billet not stamped steel, however. Be prepared to fork over your next born for them as they are overly expensive! They are very nice wheels none the less.
Bob
69rs/ssconvert is offline
rally wheels camaro9 Camaros.net Site Help Discussion 0 Sep 6th, 06 07:06 PM
1969 Rally vs. SS wheels chorne2k Wheels & Tires 1 Aug 14th, 06 10:58 AM
Can I use the 14" Rally Wheel Caps on 15" Wheels? POCKER Wheels & Tires 2 Jul 30th, 06 11:22 AM
Cragar Rally Wheels newjob1975 Wheels & Tires 0 Feb 20th, 06 08:30 AM
Rally Wheels 15x7 Backspacing newjob1975 Wheels & Tires 4 Jan 19th, 06 01:48 PM
