14" rims over disc brakes?? - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 29th, 07, 04:21 PM Thread Starter
Banned
Alan
98blackburb's Avatar
Will a 14" steel rim fit over disc brakes? Looking to go with dog dish hubcaps but am hearing they will only work as 15"s......Thanks alot...Alan
98blackburb is offline
post #2 of 6 (permalink) Old Mar 29th, 07, 05:56 PM
Re: 14" rims over disc brakes??
What year car? Factory brakes? A 14 x 7 rally wheel fit just fine on my 69 with factory front discs.
BPOS is offline
post #3 of 6 (permalink) Old Mar 29th, 07, 06:44 PM
Ted
I just pulled off a set of 14x7, 4.5bs rallys off of my 69 coupe. I have front disc brakes and had no problems with them at all. The code on them is YJ. Which I believe are for 350 SS with disc brakes. They have good rubber on them if interested.
tgifford5 is offline
post #4 of 6 (permalink) Old Mar 29th, 07, 06:58 PM
XG code 14 x 6 wheels will work over factory disc or the YJ code for I think 14 x 7. I converted to disc from drum and just went through that because I had 14 x 6 XN and they would not work. Had to find XG wheels.
bdzee is offline
post #5 of 6 (permalink) Old Mar 29th, 07, 10:59 PM
Mel
A 14" rally will also work with 4 piston calipers for vettes and 67-68 GM intermediates. as a matter of fact the rally was designed for the above mentioned applications.
So you can use a 14" rally and it should accept a dog dish hubcap.
Mel
69 Z28, DZ, M20, BU.
melav8r is offline
post #6 of 6 (permalink) Old Apr 26th, 07, 10:28 AM
I had NO luck! I have the 14x7 SS rims AND the 14x7 rallyes. They didn't fit; had to convert to 15 inch rallys.
Salerno is offline
Converting Drum brakes to disc reamo1 Brakes, Suspension & Steering 4 Jun 6th, 05 01:04 PM
Disc Brakes on an SS fb250r Brakes, Suspension & Steering 6 Apr 18th, 05 09:57 PM
Disc Brakes Speedy69 Brakes, Suspension & Steering 3 Mar 29th, 05 06:08 PM
14x6 Rally rims and disc brakes Gulcher Wheels & Tires 6 Oct 21st, 01 06:18 PM
69 Camaro SS Disc Brakes? chasd1 Tech 2000 4 May 5th, 00 09:04 AM
